Go Back   SailNet Community > Welcome to Sailnet > SailNet FAQ's
SailNet FAQ's This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
  #1
Old 06-24-2012
JeffsTsunami is on a distinguished road
Water system priming.
I'm new to this........any suggestions on how to prime my water system would be welcome. (on a Cooper 353) thanks
  #2
Old 06-25-2012
mitiempo's Avatar
Re: Water system priming.
If the pump is not worn out and is working properly you should not have to I don't think.
Brian
  #3
Old 06-25-2012
jsaronson's Avatar
jsaronson is on a distinguished road
If the tank is full, check the filters, open the valves and faucets and turn on the pump. If there is a hot water heater, it will take time for it to fill, but you should be able to feel air coming out of the faucets. If so, be patient. If not, check the pump to see if it is really pumping water or just making noise by removing the hoses and connecting the intake to a hose in a bucket of clean water.
  #4
Old 06-25-2012
Capt Len is on a distinguished road
Open galley cold tap. That eases any residual pressure. If the pump won't prime itself, wrap your lips around the faucet and suck.If that works your pump should be rebuilt or replaced before you get calluses on your lips.
  #5
Old 06-25-2012
Smile Re: Water system priming.
Thank you everyone.........It's working!!
You may post attachments
You may edit your posts
Water filtration system cla6665 General Discussion (sailing related) 2 09-07-2010 03:17 PM
Head/Water System Set up rpearlberg Gear & Maintenance 1 06-20-2010 08:37 PM
Fresh Water System daHorton Gear & Maintenance 11 05-13-2008 08:20 AM
Hot water system Borvaprops Gear & Maintenance 3 10-31-2007 05:24 PM
Water system bderosa Gear & Maintenance 4 05-31-2002 03:25 AM
SEO by vBSEO 3.6.1
