Winterizing furling jib - SailNet Community
Blogs
Go Back   SailNet Community > Welcome to Sailnet > SailNet How-to's
Old 10-21-2009
pkats is on a distinguished road
I have a furling jib and in-mast furling main on my Beneteau 343. I am in the process of winterizing the boat. What is the best practice to winterize furling jib and main? Thank you. Paul
Old 10-21-2009
badsanta is on a distinguished road
Most people remove them. But I have never removed my furling jib.
That derelict boat was another dream for somebody else, don't let it be your nightmare and a waste of your life.
Old 10-21-2009
If you truly don't plan to sail for the season, remove them and store below.
1984 Fast/Nicholson 345
Old 10-21-2009
bloodhunter's Avatar
ex-Navy
bloodhunter is on a distinguished road
pkats
If you're having your boat hauled and stored on land for the winter, many yards woon't let you keep the rollerfurling jib up
Sufficient unto the day is the evil thereof
S/V Enchantress -- Morgan 45
Old 10-21-2009
redcobra's Avatar
redcobra is on a distinguished road
My yard requires its removal if on the hard, and if I stay in the water, I wrap a bungee around it to make sure it doesn't come open at all. Main stays on in its stack pack cover. Mizzen off and below.
Alan
s/v "Zig Zag"
Pearson 39 Yawl
Old 10-21-2009
Yes, I am going to have my boat hauled and stored on land for the winter. I have to check with my marina what are the requirements.
Old 10-21-2009
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
Besides removing the genoa and storing it someplace it will not get covered in mildew over the winter it is a good idea to lube the bearings of your furler unit(s).
Sails are expensive.
Old 10-21-2009
Originally Posted by CalebD View Post
.....it is a good idea to lube the bearings of your furler unit(s)...
I was under the impression that Harken recommends fresh water flushing rather than lube.. Do I have that wrong?
Old 10-21-2009
T37Chef's Avatar
Senior Culinary Member
T37Chef will become famous soon enough
Fast,
Thats what my owners manual states. "Keep your equipment clean and free-running by frequently flushing with fresh water. Periodically clean with mild detergent and water solution. Spin sheaves and roll cars back and forth to distribute soap solution evenly."
See more here: http://www.harken.com/pdf/maintenance-lr.pdf
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary.
Old 10-21-2009
CalebD's Avatar
Tartan 27' owner
My Furlex 100S came with a tube of lube grease and the manual recommends annual lubing of upper & lower units.
I am a little surprised if Harken uses no kind of lubrication at all.
It would not be the first time I have made a general statement that was false in some specific instance.
Installing Roller Furling Sue & Larry Gear and Maintenance Articles 0 08-09-2002 09:00 PM
Jib Furling Systems - Results robrichtx Gear & Maintenance 0 12-15-2001 11:21 AM
Sail Trim Steve Colgate Learning to Sail Articles 0 05-10-2000 09:00 PM
Sail Trim Steve Colgate Seamanship Articles 0 05-10-2000 09:00 PM
Sail Trim Steve Colgate Gear and Maintenance Articles 0 05-10-2000 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
