Blogs
Go Back   SailNet Community > SailNet Website Usage > SailNet Website Technical Support
User Name
SailNet Website Technical Support Post your questions here on our new website features.
Old 07-11-2006
oil88 oil88 is offline
oil88 is on a distinguished road
Cool cutlass bearring removal
What do I need to know on how to remove the cutlass bearring from my Pearson 365?
Old 07-13-2006
sailandoar's Avatar
sailandoar sailandoar is offline
sailandoar is on a distinguished road
Cut a slot to loosen the shell ...
with the shaft removed one can use a hack saw blade or a recipocating saw (carefully) and cut a single slot all the way through. This open slot allow you to partailly collapse the shell and so loosen it in the hole. It the shell has been glued in you might need to cut a many as four or six slots and then 'peel' the resulting strips up and pull them out. Usually there are one or more set screws that sit in a dimple in the outer wall of the shell and by backing off the set screw and relieving any pressure (tight fit) by cutting a single slot the shell can be persuaded to slide out.
Display Modes
vB code is On
HTML code is Off
Teak Deck Removal petermac Gear & Maintenance 7 01-10-2008 03:13 PM
T 34 fuel tank removal Peltier Gear & Maintenance 1 12-19-2001 06:44 PM
Paint Removal hilly50 Gear & Maintenance 2 07-08-2001 07:34 AM
Help! Frozen Pin Removal. Constantin Gear & Maintenance 3 03-14-2001 07:16 AM
propshaft removal patc Gear & Maintenance 5 03-10-2001 03:37 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
