Blogs
Go Back   SailNet Community > SailNet Website Usage > SailNet Website Technical Support
User Name
SailNet Website Technical Support Post your questions here on our new website features.
Old 05-25-2008
ralphmacey's Avatar
ralphmacey ralphmacey is offline
ralphmacey is on a distinguished road
new water heater
I have a 1984 Tartan 3000 and the PO removed the water heater. I would like to reinstall a small water heater that uses both the engine coolant and electric shore power for heat. I have no idea what brand to buy and how difficult it will be to hook up, any suggestions?
Old 05-25-2008
landlockvasailor's Avatar
landlockvasailor landlockvasailor is offline
landlockvasailor is on a distinguished road
I recommend finding out why he remove and do you have a heat exchanger. If not how did he seal the bypass to the old water tank. If not that is the first item to research. If it still in tack, it is not that difficult. Best bet would be to look at someone else.
When I go, let it be by boat, with a steady breeze on the Chesapeake with a bottle of 7-up, a bag of ice, a plastic cup, and a box of wine
Old 05-26-2008
camaraderie's Avatar
camaraderie camaraderie is offline
moderate?
camaraderie has a spectacular aura aboutcamaraderie has a spectacular aura aboutcamaraderie has a spectacular aura about
A variety of small tanks are available from Rarita, Force10, Kuuma and others that will do both AC and heat exchanger based heating. Basically you hook up two hoses from your heat exchanger to the heater...one "in" and one "out". I also recommend putting two VALVES on those hoses so you can take them out of the heat exchange circuit if necessary. On the electrical side, you run and AC 3wire conduit to the heater from your breaker panel with a breaker designed to handle the amp load of the heater. Of course you will also need to bolt the heater in place. I'd look for a 6 gallon one that will fit in your available space.
Since the PO had a heater...you probably already have the taps or hose for the heater in place as well as a circuit breaker, so the job may be fairly easy to accomplish for you.
Heaters tend to be problematic over time...rusting out or needing heating elements replaced so you may wish to consider a stainless one if you plan to hold onto the boat for a while.
Moderation in temper is always a virtue; but moderation in principle is always a vice....Thomas Paine
Sponsored Ad
Old 05-26-2008
ralphmacey's Avatar
Thanks for the reply. I see there is a big price difference between the Raritan and the Force 10 or Kuuma. Some of the tanks are aluminum, some are glass lined steel [Raritan] and some are stainless. The Raritan is twice the cost. Is there a brand I should lean to?
Old 05-26-2008
moderate?
Ralph...the glass lined tank is a big plus over the aluminum ones but the price differential is IMO not worth it....if you winterize properly each year. I like the Kuuma with the stainless exterior/aluminum tank as a good price/performance mix.
Old 05-26-2008
bubb2 bubb2 is offline
bubb2 will become famous soon enoughbubb2 will become famous soon enough
I agree with Cam for the recreational sailor the Kuuma or Seaward are good units. If you are live-aboard maybe the Ratiton maybe worth it if you are planing on keeping the the boat for years and years.
Old 05-26-2008
JB2 JB2 is offline
JB2 is on a distinguished road
Seaward
We have a Seaward on our Caliber 47LRC, with both engine water and 120vac heating. The installation was very straightforward - the original one mysteriously cracked, and I had to replace it. Caliber sent us new one to Georgetown in the Bahamas for free as the old one was still under warranty. Easy to replace and re-plumb.
Display Modes
vB code is On
HTML code is Off
Flushing/testing/preping an old water system on a new old boat tenuki Gear & Maintenance 8 04-19-2007 11:33 PM
hot water heater question primerate84 Gear & Maintenance 8 10-19-2006 09:24 PM
Gifts from the Rain Gods Doreen Gounard Cruising Articles 0 03-18-2004 08:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 08:00 PM
Water Ballast/Manufacturer RSJ Buying a Boat 6 03-07-2002 06:59 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
