Go Back   SailNet Community > SailNet Website Usage > SailNet Website Technical Support
SailNet Website Technical Support Post your questions here on our new website features.
Old 09-11-2009
Dmarina is on a distinguished road
Portlight Draperies/curtains
I am planning to make our curtains for our 40' Sailboat. I would like to SEE some ideas if anyone has any. Is there somewhere, such a magazines, books, etc. that I might get some ideas. I want it to be very simple, but nice. Thanks Diane
Old 09-11-2009
lshick is on a distinguished road
Send a message via Skype™ to lshick
Diane,
The following assumes that you have the type of portlight that opens by hinging upward at the top and swinging inward. If not, ignore...
One question you want to decide is whether you want to be able to close the curtains when the ports are open (up position). If so, one solution would be to put cup hooks at the upper, outer corners, of each port, run a piece of shock cord between the two hooks, and stitch the curtain material with a tunnel/tube to run the shock cord through. When the port is closed, the shock cord runs along the top edge of the port. To open the port, unhook one end of the shock cord, pull the cord/fabric to one side, open the port, and rehook the cord running below the opened port.
Larry Shick
V42-148 "Moira"
HTML code is Off
Beneteau Lewmar portlight leak edr1 General Discussion (sailing related) 1 09-28-2009 03:40 PM
Resolving Hatch and Portlight Problems Tom Wood Gear and Maintenance Articles 0 03-17-2003 07:00 PM
