05-24-2010
Pam,
The first question is do you need to keep your fittings metric? If you are through bolting you may find that the holes will accept a standard sized bolt and are spaced properly as well. You may need to enlarge the holes a bit, but I think you will find everything to work out alright.
Also keep in mind that quite a bit of the hardware is made in countries that use the metric system, i.e. Lewmar, Ronstan, spinlock, etc.
If you are just looking for screws then try your local chandlery.
________
Vaporizer Wiki
