"New Posts" drop down menu blocked by advertisements
I often like to use the "New Posts" drop down and select "New Posts - no politics/off topic" just to see what the latest topics are.
Recently, however, the banner ad at the top of the page stays in front of the drop down box. When I click on the drop-down box arrow next to "New Posts", the drop down box drops down BEHIND the ad. Which means it's totally useless and I can't click on the option I want. Some ad don't do it, but most do. I'm supposing those ads are coded to always be on top - but that interferes with a key functionality of this site (at least to me). Thanks. |
hmmmm,.....I thought that had been fixed. Was a problem a month or so back but for me at least it has gone away.
tdw,
I appreciate your concerns and all the help you and the other mods have done for me. I also know you (mods) can only suggest things to the Admin or owners (if there is a difference). But it is the ads (and maybe other things) that have made lots of things on this site difficult to get around in. That is driving people away. |
Just another data point - I use a firm-provided laptop to access the interweb, so I can't make changes to it; e.g., using a different browser or anything like that.
Jim |
Ha! Hadn't thought of bookmarking the link. Thanks!
I have seen this problem from a few months and have messaged Sailnet Admin with no response. If the solution being proposed is 'turning off Flash' that is not a good solution. It is a work around at best. In my humble opinion the Sailnet website needs to be fixed and should not allow the Ads to be 'in front of' the menu items - in this case 'New Posts and its drop down menu'. This is Sailnet real estate and should not be covered by the Ads.
I bookmarked the link and that works fine for me now.
Btw: There are good reasons for turning off Flash and leaving it off: It's an exploit/vulnerability hole of epic proportions. It, along with many of Adobe's other products (incl., I would note, AcroRead and associated PDF applications) regularly appears on exploit risk assessment warning lists. It's almost as bad as Microsoft's ActiveTrojan, IMO. IMO it's Evil, and I utterly detest it. Jim |
| All times are GMT -4. The time now is 09:11 PM. |
SEO by vBSEO 3.6.1
