Cruising Skills/Practice - SailNet Community
 16Likes
post #1 of 43 Old 06-21-2013 Thread Starter
Hello all,
I'm moving onboard a boat I bought (surveyed, good, solid). A Pearson Triton, nicely equipped. My plan is to sail north this summer from Newport, RI. I'm trying to keep my goals to a minimum and focus mostly on being safe and enjoying myself, but I'd like to make it to Maine and if things are going really nicely to Canada. I have 2 or 3 months.
Anyway, I've sailed and raced in small boats quite a bit, and sailed a bit on larger boats, mostly as a kid. I raced in Rhodes 19s last fall and winter and have been sailing them a bit this spring too. I've had a chance to sail in some pretty windy conditions and I feel pretty good about what I'm doing with those boats.
That said, as far as sailing a moderately heavy displacement keel boat, and cruising, my actual hands-on experience is limited. I've read extensively (Pardeys etc) and have a pretty good idea what I need to do. But I'm going to have to put that book knowledge into use this summer.
(please no discouragements if you would. I'm going to do this, regardless, and I think I will be fine).
I'm going to have some time with the boat in Narragansett Bay. I can lay at anchor there for as long as I like while practicing handling this boat. I was thinking of giving myself a cirriculum of things that I should be able to do without fail before I set off. I'm just trying to figure out what that might be.
Things that I've been thinking of
1) Figure 8 mob drill
2) quickstop MOB drill
3) Find a dock or float and do touch and go landings on it from all points of sail (hopefully can find that float somewhere)
4) Anchoring under sail, dropping anchor on a run and into the wind.
5) Pulling the anchor under sail
6) Reefing the main under way (jiffy reefing)
7) changing the furling genoa to the working jib
I have ideas about other things, like maybe doing a slalom course with some little buoys, or things like that. But I was wondering if you might have anything to add to a list of essential skills for cruising? I'd like to leave Narragansett bay feeling very comfortable handling the boat by myself. Any thoughts?
sully75 is offline
post #2 of 43 Old 06-21-2013
Senior Smart Aleck
jameswilson29's Avatar
Re: Cruising Skills/Practice
8. Pissing off the side of the boat while hanging on the the shrouds and scanning the horizon for ships.
jameswilson29 is offline
post #3 of 43 Old 06-21-2013
DrB
Interesting. I usually go off the transom. Don't want to get any piss on the sheets or sail.
nkamper likes this.
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #4 of 43 Old 06-21-2013
Senior Smart Aleck
Exactly - which is why you need to practice. Pushpit peeing is for amateurs...the pulpit should be your next goal!
post #5 of 43 Old 06-21-2013
DrB
#9 and #10
#9 Changing head sails while sailing
#10 Heave-To
Also how confindent are you at handling two sails at once, especially on a gybe?
DrB is offline
post #6 of 43 Old 06-21-2013
Minnesail's Avatar
Well duh, you don't hang on the windward shrouds! Leeward peeing only.
Minnesail is offline
post #7 of 43 Old 06-21-2013
If you are single handing I would like to see what those MOB drills are??? Jump off while tethered and try to get back on? Maybe while pissing off the stern?
cranki is offline
post #8 of 43 Old 06-21-2013
Senior Smart Aleck
That would be a good drill to practice - while pissing over board, lean over the rail/lifeline and go head over heals into the drink! Then, if you remembered to attached your harness, you can "re-position" yourself, zip up your zipper, and practice hauling yourself in or, alternatively, practice drowning...
post #9 of 43 Old 06-21-2013
DrB
Isn't the sail on the LEWWARD side of the boat? So peeing while hanging on the leeward shrouds would be potentially peeing on the sheets and the sail. And how does one "Hang" on the Windward shrouds. If the boat is heeled any significant amount, you can't hang off them over the side. You would "hang" over the deck.
Most folks pee off the leeward side of the transom if they are going to pee off the boat.
mark2gmtrans likes this.
DrB is offline
post #10 of 43 Old 06-21-2013
sailing soon
mark2gmtrans's Avatar
Send a message via Yahoo to mark2gmtrans
Hmm, finally another thread where one can find salient advice on the art of cruising....
Of course if cruising one may expect the need to piss to occur and therefore should study the matter carefully. I would suggest having your crew position themselves about the boat along the rails and in other key positions, then haul your dinghy into position and let them monitor the spray array.
It is good to learn from your mistakes, but much better to learn from the mistakes of others...
mark2gmtrans is offline
sextant practice MarkCK Gear & Maintenance 22 01-21-2013 12:39 PM
What should i practice next? Fau Learning to Sail 10 07-29-2012 09:07 PM
Practice on land? WDfrmTN Learning to Sail 6 05-11-2011 12:20 PM
Minimum Skills to Bootstrap into Cruising IntrepidManiac Cruising & Liveaboard Forum 12 04-05-2010 10:21 AM
Optimizing Your Practice Carol Cronin Racing Articles 0 04-10-2002 08:00 PM
