Give way when hoisting the main? - Page 4 - SailNet Community
 13Likes
post #31 of 33 Old 08-13-2013
jackdale's Avatar
Re: Give way when hoisting the main?
Lesley - the only advise I can offer is be vigilant and assume nothing. One thing many folks forget is that you can avoidance some collisions by slowing down.
JomsViking likes this.
jackdale is offline
post #32 of 33 Old 08-14-2013
Lesley,
Nothing is certain in love, war, or how to apportion fault in most vessel collisions.
But starting up and using the engine as a "last ditch" maneuver to avoid, or try to avoid collsion is probably within the things Rule 17(b) means when it says "...if collision cannot be avoided by the action of the give-way vessel alone, she (meaining the stand-on vessel) shall take such action as will best aid to avoid collision".
So you may be wrong NOT to use engine if you could have, in what we call the "jaws of collision" or "in extremis". And if you guessed wrong about whether to turn this way or that "in extremis" even though it was an arguably reasonable "bail-out" try at the time (though maybe not in retrospect), the maritime law tends to look with a more understanding view of "error in extremis" when that error resulted from a tough choice with too little time to think about it, forced upon you by the other vessel (who should have given way much earlier) .
So a definite "maybe" to your very good question. But using your engine at the last second in such a crisis in order to turn away when everything before that was pure sail, "most probably" wouldn't change your pre-existing status as a sailboat for the application of the "sail over Power" provisions of rule 18
LesleyS likes this.
nolatom is offline
post #33 of 33 Old 08-14-2013
nolatom - thanks for the very helpful clarification, and your expansion to include the unanticipated consequence of becoming a "power vessel" as a last ditch effort to avoid collision.
As I said, You are definitely my first choice for lawyer should I ever need one! (Here's hoping I never do.... In which case I'll just buy you a drink should our paths ever cross :-)
LesleyS is offline
Hoisting an inflatable dinghy MarkSailor General Discussion (sailing related) 4 07-21-2013 10:25 PM
Hoisting the jib! radioguy General Discussion (sailing related) 14 08-02-2010 02:02 AM
hoisting a large anchor rosskowh SailNet FAQ 23 06-18-2010 01:49 PM
Hoisting RIB's on Deck Dave H General Discussion (sailing related) 5 04-02-2007 01:01 AM
Before Hoisting the Halyard Bruce Caldwell Learning to Sail Articles 0 10-07-2003 08:00 PM
