Why the Bristol 32 backs so poorly - Page 3 - SailNet Community
 21Likes
post #21 of 32 Old 12-18-2013
Re: Why the Bristol 32 backs so poorly
Barquito, Went over your simple equation and unless I'm missing something ,I think that the maths would be improved by adding the universal concept of Zs (zenith of scat) which factors in the level in the holding tank at the instant of contact with the piling.
Capt Len is offline
post #22 of 32 Old 12-18-2013
Originally Posted by jb1528 View Post
MarkSF,
I guess we all have times when we control our boats without actually steering. The back and fill maneuver comes to mind. Some call that seamanship.
I have a Bristol 32 and can relate to the backing thing.
Jim
I just try to think of her behaviour as endearing.
Delta-T likes this.
MarkSF is offline
post #23 of 32 Old 12-18-2013
My Hunter 23.5 water ballasted trailer sailer can be a handful to back out of a slip when the wind is side on to the slip. The bow blows down so easily I have to really try to predict how I'm going to be blown when I clear the finger. I have backed all the way down the fairway before being able to turn. I have done this in larger boats too when propwalk was such an issue that I couldn't turn into the wind. It doesn't embarrass me anymore to back all the way down a fairway when I have to. I can't imagine not being able to predict which way your boat will propwalk or being able to control once having steering way.
Kevin
Tallswede is offline
post #24 of 32 Old 12-19-2013
Delta-T's Avatar
And all this time I thought it was just me, 38 years on this boat. I have also been in the same yard and in the last few years they have brought in a sailing teaching school and I see them practicing backing up long distances and am in awe. My dream is to retire on a 40+' with a bow thruster. That is my idea of heaven.
jimgo likes this.
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
post #25 of 32 Old 12-22-2013
I think it's just a bad place for a rudder when backing is the issue. I had seen a boat a couple years back that was, I think, an Alberg 30. It was a Texas boat and was for sale. On the hard, it was obvious it'd been modified. The keel was all there, but the rudder was decidedly out-of-place. The aft edge of the keel was clean, no rudder. It'd been faired out, looked good. The rudder was much further back. I wrote the guy and he explained that they'd done it for improved handling. While the original rudder was fine for cruising (in forward), they wanted more. He'd had a spade rudder installed. He said the difference was incredible, that it'd turn much faster, and controlled backing was actually possible, even enjoyable. He went on to say that they had to re-work the steering ratio because it was so much quicker responding to steering inputs. He did also relate the common malady of the spade being that in rough water it was in the air often, so it wasn't a sales pitch. I made it clear I was curious about the rudder and was not a buyer in my opening sentence. Had questions about the trailer as well. Anyway, I think that, as much as anything demonstrates the poor rudder authority of the Bristol 32, and similar designs when backing. It really seems to have been an afterthought at best, and not a big concern. "Where do you want best performance, a few minutes backing, or hours, even days going forward?" Maybe that's what they were thinking. Seems to me, a modest stern-hung blade would suffice for such maneuvering situations. Perhaps one that could be flipped up out of the water once clear to navigate. I've often wondered how much better it would perform if the Bristol 32 rudder extended even maybe another 6-8 inches back on the trailing edge. There's really not much there to begin with. The upper third of the blade is pretty useless since most of it is not there (prop aperture). It keeps with the overall lines visually, but that only matters when not in the water. It should be lengthened. Another, say, six inches would give more bite on the lower part, and actually restore function to the upper third of the blade. Maybe, one day, I will be able to test that theory, but I won't be upset if someone else does it first.
seabreeze_97 is offline
post #26 of 32 Old 12-22-2013
Found it. It is a 1963 Pearson Vanguard 33. Check out that rudder mod.
Pearson Vanguard 33 yacht for sale
post #27 of 32 Old 12-23-2013
Delta-T's Avatar
What I do love about my setup is I can walk all over lobster pot lines all day long without getting hung up. And that includes under power...
christian.hess likes this.
Eric
Delta-T
Delta-T is offline
post #28 of 32 Old 12-23-2013
Group9's Avatar
Why? Probably the same reason every inboard sailboat I've ever had backed poorly. Because they are designed to be going forward 99.99999 per cent of the time.
On the northern Gulf of Mexico.
"Best thing to do is get her out on the ocean. If anything's gonna happen, it's gonna happen out there." Captain Ron Rico
Group9 is offline
post #29 of 32 Old 12-23-2013
Agreed, and that goes to what I was saying. There gonna be a trade-off. So where do you want the function to be best, a few minutes here, or the rest of the time out there? Don't get me wrong. I actually learned on a Catalina 310 (spade rudder). That thing would spin so easily you could almost just think it, and it'd do it (marina maneuvering under way was great, but even it suffered prop walk in certain situations), but out in some chop the rudder authority was not so great because it was constantly aerating. See how your rudder is deeper behind the prop? If the non-centerboarder had that extra depth in the same place, and for the full length of the rudder, I think it'd be the best compromise to achieve somewhat better backing control.
post #30 of 32 Old 12-23-2013
mstern's Avatar
Delta: how did you accomplish your rudder replacement? Professionally designed? Cost (if I may be so bold as to inquire)?
mstern is offline
Singlehanded Running Backs northoceanbeach Racing 11 03-23-2013 02:18 AM
Sailing poorly upwind asdf38 General Discussion (sailing related) 16 08-08-2011 12:16 PM
Long, boring, and poorly written trip report... ughmo2000 General Discussion (sailing related) 15 02-19-2010 09:11 AM
Poorly Running 9.9 Merc Outboard SpeedAgent Gear & Maintenance 17 04-18-2009 10:21 PM
