A harrowing tale from Cape Scott - Page 2 - SailNet Community
 3Likes
post #11 of 16 Old 09-01-2013
flandria's Avatar
Dock
Re: A harrowing tale from Cape Scott
Originally Posted by katsailor View Post
I can see difficulty in setting the cqr type if it is laying in it's side. I think it needs to be in an upright configuration for the plow to dig into the bottom..
I think that the CQR needs to be on its side to dig in. The only other position it can have is to be on its back, with the flukes pointing up, and it certainly will not dig in when in that position. For the "pointy end" to be pointing down, it would be doing a balancing act which, if not impossible in a sandy bottom (for example) would be a rare event - and would give a good result.
flandria is offline
post #12 of 16 Old 09-03-2013 Thread Starter
Break, curse, fix, repeat
bwindrope's Avatar
I don't think your points are necessarily wrong or bad, but I don't know that they are generally always true. Dragging anchor can happen for many reasons, including having insufficient scope. If that is your problem, then lengthening rode can absolutely solve the problem. For example, if you drop your hook with 2:1 on a lunch stop and then 30 knots comes up, you are likely to drag in a way that more scope might solve. However, if any dragging at all results in you hitting or something soon, it would be wise to raise anchor and go elsewhere!
And I can say from experience there is no particular reason to not back down hard on a Mantus, but of course this is a question of degrees. We are generally dead in the water when the hook is dropped, and so even by engaging revers and getting going we are pulling back on a length of chain from a dead stop and do not hit anything resembling high speeds! But we pull back good and hard and find the boat comes to a definite and sudden but gentle stop. There is no shuddering or calamity to it. You just stop going back and some of that energy gets translated into the boat straightening out. We do it this way every time and have never had any trouble whatsoever, and in fact, have had nothing but resounding success both in terms of anchor setting and retrieval.
And as for the CQR, the testing I have seen suggests the CQR is unlikely to dig in much no matter what the orientation. It is simply not good at doing so to any meaningful depth. Which again, is fine in most situations because the weight of the anchor and rode and friction with the bottom is enough to prevent movement in most conditions. But when it is rough, the setting depth and tenacity of the Mantus or other modern hooks makes the difference in not moving.
I read someone recently say that we make all this stuff too complicated! There are ways that is true, but one of the necessities and appeals of sailing is the technical aspect of things, so there you go!
Aeolus
Gulf 32
Bainbridge Island, WA
bwindrope is offline
post #13 of 16 Old 09-03-2013
flandria's Avatar
Dock
Thx bwindrope for the comment.
My own observation starts with the premise that sufficient scope has been paid out when anchoring, to begin. This is when I, personally, suspect that the anchor is not doing its job, in spite of all the chain and friction, and, rather than hope for the best as we drag, start anew.
That said, I don't think we at all disagree on the amount of force/momentum/boat speed used when setting the anchor.
It's just that I have witnessed both extremes: dumping the entire chain-scope on top of the anchor, or, conversely, going forward full-steam with chain rattling out and then have the boat come to a rather sudden stop.
flandria is offline
post #14 of 16 Old 09-03-2013
Originally Posted by flandria View Post
......It's just that I have witnessed both extremes: dumping the entire chain-scope on top of the anchor, or, conversely, going forward full-steam with chain rattling out and then have the boat come to a rather sudden stop.
As have we... I don't think it's necessary to be as brutal as a fast forward drop.. esp with all-chain it puts a ridiculous load on the windlass.. But I think the 'dump the entire rode and then drag it out' approach is also flawed, the odds of a loop of chain grabbing an anchor fluke and preventing a proper set is just too high.
I think you need to be moving backwards slowly by the time your anchor hits the bottom.
jackdale likes this.
Faster is offline
post #15 of 16 Old 09-06-2013
jackdale's Avatar
When I am anchoring I will stop lower rode at about 3:1 and give the rode a little toug. That seems to help turn an anchor over and help it. set.
As an aside - I would not have left Bull Harbour under those conditions. I spend a lot time in Port Hardy getting weatherfaxes and grib files before I ever depart. SE winds are simply bad news. I might not have even left Port Hardy. Twice I have not gone around because of the conditions.
jackdale is offline
post #16 of 16 Old 09-06-2013 Thread Starter
bwindrope's Avatar
I'm with you Jackdale, and that is just good sense and local knowledge. I don't know what their forecasts were, as we were not in Bull Harbor with them, but assuming the strong SE winds were forecast then I wouldn't have gone either.
The day we went around Cape Scott it was a mill pond with moderate gentle swells.
But the interest of the story remains, and the chance for each of us to rehearse what we might do is quite useful. All the mental reps we can take about these sorts of calamities make us better sailors.
Aeolus
Gulf 32
harrowing story administrator General Discussion (sailing related) 18 07-14-2013 04:37 PM
Harrowing ordeal at sea for Pointe-Claire pair; Couple tell of survival and ... - Wes NewsReader News Feeds 0 11-21-2012 09:20 AM
Sea Major/Scott Smith Seamajor Introduce Yourself 2 06-20-2012 05:50 PM
Harrowing Lake Huron Experience Off Port Elgin - CKNX Radio NewsReader News Feeds 0 07-26-2007 05:15 PM
Crew thrilled to see land after harrowing journey - Toledo Blade NewsReader News Feeds 0 07-01-2007 07:15 AM
