iPad - the charging conundrum - Page 2 - SailNet Community
 5Likes
post #11 of 28 Old 11-26-2013
Re: iPad - the charging conundrum
Originally Posted by tarmes View Post
Yes, but I'm tackling one issue at a time.
It doesn't make a whole lot of sense to tackle one thing at a time when they are interrelated. If you need lights then you need a basic electrical system, which can be extended to cover the iPad problem and bilge pump problems.
By the way, have a small solar charger on my 12' dingy which I use to get to my moored boat. It keeps the battery charged very well and has no controller. I don't run the outboard enough in the short hop to the big boat to charge the battery but the solar keeps the starter and the bilge pump for the open dingy and the running lights operating well for the whole summer.
smackdaddy likes this.
genieskip
Northeast
J40
1991
genieskip is offline
post #12 of 28 Old 11-26-2013
The Elephant
smackdaddy's Avatar
Spending money and time on a chartplotter setup before your boat is ready to sail (no nav lights, no bilge pump, etc.) doesn't make a lot of sense to me. Do the important stuff first.
Atlas and Alex W like this.
smackdaddy is online now
post #13 of 28 Old 11-26-2013
Maine Sail's Avatar
If your bilge pump or loads run enough you can get away with it but if you go without rain or don't use loads for a period of time even small panels can and will over charge and damage batteries. I see this over and over again. I see it so much I finally made a video to bring more awareness to it... Web sites such as the West Advisor are so wrong on this that it gets downright scary.....
______
-Maine Sail / CS-36T
Maine Sail is offline
The Following User Says Thank You to Maine Sail For This Useful Post:
genieskip (11-26-2013)
post #14 of 28 Old 11-26-2013 Thread Starter
It's not quite as mad as it seems:
* I don't need a bilge pump because there's no bilge
* I will be installing Nav Lights, but it'll be a while before I'll be navigating at night, so that's not an immediate priority, but it does need thinking about now for the future. For the small size of boat I just need a tricolour at the top of the mast.
It's a very small boat and I don't wish to be too excessive. There are currently no other electrical requirement at the moment other than the iPad. The log runs off of some AA batteries as do the interior LED lights.
tarmes is offline
post #15 of 28 Old 11-26-2013 Thread Starter
Hi,
What set-up would you recommend for my use case? I basically need to run an iPad and some LED nav lights and have the battery charged by a solar panel.
It would be nice to have room for extendibility in the future, just in case.
Regards,
Tim
tarmes is offline
post #16 of 28 Old 11-26-2013
The Elephant
smackdaddy's Avatar
Oh, okay - that makes sense. So it's just a small daysailer. Carry on then!
post #17 of 28 Old 11-26-2013
Maine Sail's Avatar
Hi,
Regards,
Tim
Small battery - group 24 or 27
Main Battery Fuse
Battery Switch
Small 6 position DC panel
12V Outlet
Small 20-30W panel with PWM controller
______
post #18 of 28 Old 11-26-2013
The Elephant
smackdaddy's Avatar
Main Battery Fuse
Battery Switch
12V Outlet
Main - I guess now that I understand his boat a bit better, my question is why he needs a solar panel at all. If it's on a trailer and he's only daysailing it, can't he just pull the battery and charge it at home?
post #19 of 28 Old 11-26-2013 Thread Starter
I'd like to be able to take it away for a few days sailing at a time, perhaps a weeks worth. Charging in that way may therefore not be an option.
I could potentially charge the battery using shore power in a port, but then the electrical system gets rather more complicated and expensive.
tarmes is offline
post #20 of 28 Old 11-26-2013 Thread Starter
Main Battery Fuse
Battery Switch
12V Outlet
Please excuse my ignorance of electrical systems, but how can I be sure that the the system can keep the iPad running? If would be nice if the the panel could deliver enough power to the battery to charge the iPad even when it's being used.
tarmes is offline
The iPad thread! who uses an iPad for sailing? NewportNewbie Apps & Authors 71 02-10-2014 03:36 AM
Speed/Depth/Wind conundrum Rhys05 Gear & Maintenance 25 02-02-2013 09:38 PM
Solar Conundrum Skipper Joe Gear & Maintenance 13 07-28-2012 02:34 AM
A Nice Little Conundrum tdw General Discussion (sailing related) 66 06-21-2011 03:21 PM
A Conundrum, without an Answer Jasper Windvane General Discussion (sailing related) 50 11-17-2009 09:15 PM
