sailing on 'headsail' - SailNet Community
 5Likes
post #1 of 42 Old 12-13-2013 Thread Starter
Question sailing on 'headsail'
Do you 'gybe', or 'tack', when on only 'headsail', and why one or the other? Thanks.
AirborneSF is offline
post #2 of 42 Old 12-13-2013
Maine Sail's Avatar
Re: sailing on 'headsail'
Both, just depends what I am doing, where I am going or what I am avoiding.......
tomandchris likes this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #3 of 42 Old 12-13-2013 Thread Starter
Thanks, one of the reasons for asking is this past spring it seemed when 'tacking' you can almost end up 'hove-to', yes?????????????
post #4 of 42 Old 12-13-2013
Sabreman's Avatar
Depends in which way you're headed relative to the wind. When passing through the wind, headed upwind (into the wind), it's a tack. When passing through the wind headed downwind, it's a gybe.
Sabre 38 "Victoria"
Sabreman is offline
post #5 of 42 Old 12-13-2013
MarkofSeaLife's Avatar
Dock
Its the same as if you have a main sail up.
Tack when the bow goes into the wind, gybe when the stern goes into the wind.
Mark
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #6 of 42 Old 12-13-2013
With head sail alone, I can not tack. I have a full keel with cutaway forefoot.
lancelot9898 is offline
post #7 of 42 Old 12-13-2013
Sabreman's Avatar
By hove-to, I believe that you're meaning "in irons". Yes, that happens when you tack without enough forward momentum.
In super light air (e.g., < 1 kt) it can sometimes be more efficient to do an old square rigger move called "wearing ship" and gybe rather than tack. But that's an exception and not the norm.
Sabre 38 "Victoria"
Sabreman is offline
post #8 of 42 Old 12-13-2013
Chastened
Ajax_MD's Avatar
Sailing under jib alone= Wanking.
Bringing the bow through the wind= Tack.
Bringing the stern through the wind= Gybe.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #9 of 42 Old 12-13-2013
Minnesail's Avatar
Really?!? Are you having us on?
Catalina 22
on a starboard tack
Minnesail is offline
post #10 of 42 Old 12-13-2013
If the jib is too small, it's hard to tack. When most or all of the sail area is forward of the CLR, then when you tack, the jib pulls the bow to leeward, and it's very difficult to get the boat to sail to windward on the new tack. If the jib is about 130% or larger, the overlap provides some sail area aft of the CLR, and that part of the jib helps push the stern to leeward, which helps the boat come up to windward after tacking. So, sailing on a non-overlapping jib alone doesn't work very well, if you will have to tack the boat.
Sailormon6 is offline
New headsail PaulinVictoria Gear & Maintenance 27 12-28-2013 02:30 PM
Sailing dinghy w/o headsail FlyingJunior Learning to Sail 15 12-03-2012 05:06 PM
Name this headsail jjablonowski Seamanship & Navigation 7 05-19-2011 02:15 AM
Headsail Bags glmark Gear & Maintenance 1 04-18-2011 03:18 PM
converting a furling headsail to a hanked on headsail mrkeith Gear & Maintenance 6 02-15-2007 02:36 PM
