How much wave/swell is too much? - Page 3 - SailNet Community
 6Likes
post #21 of 23 Old 12-29-2013
Courtney the Dancer
jrd22's Avatar
Re: How much wave/swell is too much?
Islanderguy at the beginning of the thread gave some excellent advice about the relationship of height/time. If the height is greater than the time it's going to be very uncomfortable and possibly dangerous. The other factor to consider, even in protected waters like here in the PNW is the wind against the currents. It can get decidedly nasty with even a moderate breeze of 20 knots against a 3-4 kt current, I've seen breaking 8' waves in 30 knot wind against a 4-5 kt current in front of our marina.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #22 of 23 Old 12-29-2013
I use Dial-A-Buoy quite a bit before i go out when i don't have computer access. Obviously you have to be within cell range.
NDBC - Dial-A-Buoy
I keep a laminated sheet with instructions and buoy ID on board so i can check conditions when i'm out for long periods. As you know, conditions can change rapidly if the weather shifts.
National Data Buoy Center
I also use Weatherforyou.com and sailflow
Buoy Center - Buoy Map
As far as what is to much? You'll have to figure that one out on your own.
Depends, IE, Type of boat, Size, experience, Duration you will be in it, skill level, what will it be like when you come into port?
At some point you will discover your limit and/or your boats limit if you challenge yourself. You may not want to go there.
I enjoy heavy weather sailing (my wife loves it, scary) but, i do it in short spurts. Not for days. It will definitely sharpen your skills, especially when things break.
I'm stuck on Lake Ontario for now. It's some of the roughest water i've seen. 10 ft with a close freq can really be a long day if you are caught out (i feared for the boat that day, not mine, 34' C&C). We had the coast guard get rolled twice in 12-14 ft waves. Put three of them in the hospital. I had talked to the Chief PO after. They had one engine go out.
Watertown Daily Times | 5 US Coast Guardsmen hurt during Lake Ontario training
benesailor is offline
post #23 of 23 Old 12-29-2013
Barquito
Barquito's Avatar
I take it tonight would be rough night out on Lake Michigan:
Valiant 32
Barquito is offline
Timaru a swell spot for sailing NewsReader News Feeds 0 09-30-2011 08:10 PM
Swell definition pmusu General Discussion (sailing related) 47 02-13-2009 11:02 PM
Swell Direction in the Leeward Islands ArgleBargle Chartering 7 11-23-2008 06:13 PM
Swell direction in the leewards ArgleBargle Cruising & Liveaboard Forum 1 09-24-2008 05:01 PM
Square wave or sine wave inverter? wingNwing Gear & Maintenance 14 05-04-2008 10:06 AM
