ASA Coastal Nav Exam - HELP - Page 2 - SailNet Community
 2Likes
post #11 of 28 Old 02-24-2014
But if not...
Re: ASA Coastal Nav Exam - HELP
I learned it (and practice it) as JackDale describes. Advance the initial LOP based on time and course traveled between the 2 LOPs.
paperbird is offline
post #12 of 28 Old 02-24-2014
jackdale's Avatar
I used the Tools in OpenCPN and Elements to show my plotting. That special purpose buoy is not shown in this chart, so I used its lat and long
Be careful with labelling as well. In Sail Canada (CYA) plotting and labeling is worth marks. Is that also true in ASA?
I have just done a cross over from Sail Canada to ASA. I have to do 214 (catamaran) separately, so I am going to Sausalito next week. So I am also studying. Any advise would be gratefully accepted.
jackdale is offline
post #13 of 28 Old 02-24-2014 Thread Starter
Learning the HARD way...
eherlihy's Avatar
Thanks jackdale!
While very similar to what I did, it was not the same. I forget this stuff!
Based on your notes, here is my solution to the problem;
Step 0: Plot the intended course & danger bearing;
Step 1: Establish LOP on known object;
Step 2; Maintain course and heading for specific time, and establish second LOP on the same object;
Step 3; Advance LOP from first bearing by the distance traveled using 60 * D = S T;
Step 4: Running Fix is where the two lines cross. Plot Course Made Good (CMG);
eherlihy is online now
post #14 of 28 Old 02-24-2014
But if not...
Next steps:
- plot original DR position anticipated at 1620
- compare 1620 running fix to 1620 DR and calculate set and drift
- apply set and drift to DR course out of 1620 running fix or, better still, recommend course change out of 1620 running fix to compensate for set/drift and still avoid being run up on the lee shore of Pt Judith Neck.
post #15 of 28 Old 02-24-2014
jackdale's Avatar
Originally Posted by eherlihy View Post
Thanks jackdale!
Your plotting looks good. Check the labeling. I forgot to to label the course line. It should also have one arrow on it.
C 354_____>_________
S 4.0
The CMG line should have two arrows.
jackdale is offline
post #16 of 28 Old 02-24-2014
jackdale's Avatar
Originally Posted by paperbird View Post
Next steps:
You need a departure time from the buoy to get a DR.
jackdale is offline
post #17 of 28 Old 02-24-2014 Thread Starter
eherlihy's Avatar
S 4.0
Like this?
post #18 of 28 Old 02-24-2014
jackdale's Avatar
Like this?
Exactly.
I was also taught to put hash marks in a danger bearing line and label as either NLT or NMT
_______NLT 090__________________________!
jackdale is offline
post #19 of 28 Old 02-24-2014
jackdale's Avatar
The course line should have the course in true on top and the speed (from the knotmeter) on the bottom.
jackdale is offline
post #20 of 28 Old 02-24-2014 Thread Starter
eherlihy's Avatar
I pulled up a copy of the 1210tr chart from Ocean Graphics;http://www.oceangrafix.com/chart/zoom?chart=1210TR .
Not sure.... IIRC, ASA only looked at the fill_in_the_dots answer sheet.
I'd love to help, but I'm having enough trouble with one hull. Good luck on the test!
HAM Radio Exam.....prep? Cruiser2B General Discussion (sailing related) 10 12-22-2012 01:03 PM
CPYB exam QuickMick General Discussion (sailing related) 1 01-05-2012 02:59 PM
ASA 101 Exam MauritiusDiver Learning to Sail 3 08-08-2008 12:17 AM
study for ham license exam chuck5499 Cruising & Liveaboard Forum 4 11-14-2006 11:23 PM
IT exam preps ? ganeash Announcements and Suggestions Box 0 11-13-2006 03:25 AM
