Radar signature - Page 2 - SailNet Community
 11Likes
post #11 of 34 Old 02-19-2014
Re: Radar signature
Originally Posted by FSMike View Post
I have a vague recollection of somebody (the Pardeys?) stuffing a hollow wooden mast with foil and having good reports on its signal return. If it wasn't them I apologize.
That's correct. It was the Pardeys. They put long strips of aluminium foil inside their hollow wooden mast (box construction) and had excellent results. I think this will only work on a wooden mast however.
Vindö 50
copacabana is offline
post #12 of 34 Old 02-19-2014
Yorksailor's Avatar
Re: Radar signature
We have over 100 large ship interactions, in open waters, per year and talk on the VHF to at least 25.
Even though we transmit on AIS we have to call them on the VHF to get them to look at their radar and AIS. At least 50% of the ships we call take up to 5 minutes to acknowledge our presence.
Except perhaps in fog, imagining that they are looking for small blips on their radar will get you killed.
davidpm and vtsailguy like this.
Yorksailor is offline
post #13 of 34 Old 02-19-2014
Courtney the Dancer
jrd22's Avatar
Re: Radar signature
I agree with York, while there is nothing wrong with installing something to try and reflect a better radar return I think it gives people a largely false sense of security. Actively monitoring your radar and AIS if you have it to avoid the big boys is by far the safest route to go. To answer the OP's question, we have the Davis and have viewed the sailboats radar return from another boat and it is quite visible.
Faster, fryewe and davidpm like this.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #14 of 34 Old 02-19-2014
Re: Radar signature
My random thoughts...
The corner reflector (the spherical type with intersecting disks) is designed to work at all angles of heel since the idea of the "corner" is to create a 180 degree reflection using the two or three surfaces of the corner as long as the radar enters the corner +/-45 (90 degrees of returnable angle) degrees. In the spherical design once that corner rotates out of it's returnable path the next one rotates in so it works at all angles. The strongest return is when you have a whole disk aligned perpindicular with the source since you basically have two corners reflecting at that point, but on a bobbing rocking boat (The source is also rocking and bobbing) it's impossible to keep it aligned without some active alignment. The bigger the cross section reflector the bigger the return. Unfortunately the size of the disk that can be reasonably placed in a sailboat's rigging is somewhat small.
Putting metal in a metal mast won't accomplish anything. The radar is reflected by the mast itself, but the circular shape of the mast only returns a small portion to the source as the rest is scattered radially, and a boxed mast (square tubing) would only reflect, although very well, when it's aligned perpindicular to the source (vertically and rotationally). A wooden mast is basically transparent to radar so metal in a wooden mast would be of benefit.
Also, adding to it is the radar operator. If he has his gain turned down to eliminate sea clutter and only see the signature of a 500 foot steel hull so he doesn't have to stare at the screen except once in a while when there is a return, you won't be seen no matter what kind of dinky reflector you have.
AIS is cool but not everyone has them yet. And you can still run into another smaller pleasure boat not required to carry it.
So best I can offer is: Do what you can, keep a good watch when you can, keep some rum close at hand for the close shaves, and pray to the gods for safe passage.
davidpm and Minnesail like this.
CaptDave is offline
post #15 of 34 Old 02-19-2014
Re: Radar signature
Here is a test from 2005 - don't think much have happened since then
http://www.yachtingmonthly.com/fileB...ce_ym_june.pdf
One more
http://www.maib.gov.uk/cms_resources...s%20report.pdf
knuterikt is offline
The Following User Says Thank You to knuterikt For This Useful Post:
Argyle38 (02-19-2014)
post #16 of 34 Old 02-19-2014
outbound's Avatar
Re: Radar signature
got three little plastic lobules packed with reflectors mounted to the mast just above where the storm jib stay goes. Surface is smooth so doesn't interfere with lines/sails. Weight is minimal. Thing is white so not a eye sore. Blocking brand name. will post if it comes to me. Had friend check out if I show up on his radar. At 10m at least in absence of sea clutter/rain I do. Might be a good way to go. Running radar is a huge draw. When sailing usually leave in standby and pulse every once in awhile. Turn if off if not in lanes, fog etc. Now with commercial traffic required to have AIS think rather then blowing money on active returns spend the money on AIS.
s/v Hippocampus
Outbound 46
outbound is offline
post #17 of 34 Old 02-19-2014
outbound's Avatar
Re: Radar signature
Viking tri lens standard
fryewe likes this.
s/v Hippocampus
Outbound 46
outbound is offline
post #18 of 34 Old 02-19-2014
Re: Radar signature & Radar Flare
The report referenced is what I used to select the TriLens. I have not heard that wet sails impact performance. Makes me wonder what happens with sails that have a carbon fiber matrix laminated inside.
I always wanted to have a few radar flares on board for emergency but I could never find a place to buy them. A radar flare launches a whole lot of aluminum chafe or streamers and makes a temporary radar image about the size of a supertanker.
GTJ
SailingJackson is offline
post #19 of 34 Old 02-19-2014
davidpm's Avatar
GTJ
That is a new one to me.
So you launch your radar flare.
You are only a mile away and suddenly look like an aircraft carrier.
The guy on the taker bridge has heart failure and runs you down.
Unintended consequences.
davidpm is offline
post #20 of 34 Old 02-19-2014
GTJ
How long will it last?
What about a DIY project, it's only strips of tin foil and a launch system
The British Harriers used that stuffed behind the airbrake as a one dose chaff in the Falklands war.
Signature Box Lostmt Announcements and Suggestions Box 0 06-17-2006 08:01 AM
Signature II, one berth open lacrosse.d.p. Crew Wanted/Available 4 02-02-2001 05:26 AM
