Charts to Bermuda from Chesapeake Bay - SailNet Community
 4Likes
post #1 of 12 Old 03-24-2014 Thread Starter
mrmac's Avatar
Is there a single paper chart that covers the sailing area from Norfolk to Bermuda? If not, is there a chart book that includes charts for that entire trip?
Thanks,
mrmac
mrmac is offline
post #2 of 12 Old 03-24-2014
jsaronson's Avatar
Re: Charts to Bermuda from Chesapeake Bay
There is a planing chart Newport to Bermuda. Number is 5161. You also need 13003. You'll need a detailed chart of the Island.
jameswilson29 and mrmac like this.
jsaronson is offline
The Following User Says Thank You to jsaronson For This Useful Post:
mrmac (03-24-2014)
post #3 of 12 Old 03-24-2014
There may have been some futher changes,ie safety equipment,since I've sailed there..
http://www.gotobermuda.com/get-here/...rivate-vessel/
mrmac likes this.
aa3jy is offline
post #4 of 12 Old 03-24-2014 Thread Starter
mrmac's Avatar
jsaronson - that's what I had come up with but had hoped that there was a single chart covering the whole thing. I have the charts on a netbook but would like to take a look at the trip on paper charts. As a cheap crew member, I was trying to keep my costs down.
Do sailors come out of the Chesapeake Bay and just head straight for Bermuda as best the winds and currents will allow?
mrmac is offline
post #5 of 12 Old 03-24-2014
billyruffn's Avatar
Passage, approach, and entry charts are the minimum, but don't forget charts needed for an aborted passage. Where are you going to go if X happens and you need to divert somewhere south of Cape Henry? It's good to have approach and entry charts for a couple of harbors in NC. Wilmington.
billyruffn is offline
post #6 of 12 Old 03-24-2014
jsaronson's Avatar
Yes, BUT!! It takes the right boat, properly equipped with the right crew. Races to Bermuda are category 1 for a reason. Here is a list of safety requirements as a guide:
http://www.bermudaoceanrace.com/imag...BOSR030214.pdf
It is not a trip for a novice, and don't attempt a Stream crossing in a northerly wind.
mrmac (03-24-2014)
post #7 of 12 Old 03-24-2014 Thread Starter
mrmac's Avatar
Thanks for the Bermuda race regs, jsaronson. May I have your thoughts on seaworthiness of catamarans with respect to sliding glass door from cockpit into salon?
mrmac is offline
post #8 of 12 Old 03-24-2014
You can also see what information is available on the Navionics app and charts by going here: WebApp | Navionics
so you can see the maps before purchasing the app or chips.
Here is a screenshot of the Bermuda area
As far as seaworthiness of a catamaran with a sliding door into the salon, there have been many a catamaran with sliders that circumnavigated and faced some pretty rough conditions. My advice, close the door when you're in rough seas. You'll be good.
jerryRiggin is offline
The Following User Says Thank You to jerryRiggin For This Useful Post:
mrmac (03-24-2014)
post #9 of 12 Old 03-25-2014
Mermaid Hunter
SVAuspicious's Avatar
Pretty much. Note you have pick relatively early whether to go around North or South to get to Town Cut.
Also note that the Gulf Stream is northeasterly between either Newport or Norfolk and Bermuda.
SVAuspicious is offline
post #10 of 12 Old 03-25-2014
jsaronson's Avatar
I don't know enough about cats to comment. I'd look for good design and construction.
Tags
bermuda , charts
Chesapeake to Bermuda - share your wisdom rockDAWG General Discussion (sailing related) 17 05-17-2011 10:53 AM
Online charts of chesapeake bay zz4gta Gear & Maintenance 11 09-28-2007 06:59 AM
Chesapeake to Bermuda and BVI in December? magnusmurphy Cruising & Liveaboard Forum 4 08-20-2007 10:22 AM
Charts & Guides, Chesapeake to Sarasota, FL Bruceo1 General Discussion (sailing related) 3 03-08-2005 02:53 PM
Chesapeake bay to Bermuda Spring 2004 albertegan Cruising & Liveaboard Forum 0 08-30-2003 02:36 PM
