Boom Preventer or Not? - Page 2 - SailNet Community
post #11 of 19 Old 06-20-2001
paulk's Avatar
It looks like that by double-ending the line at the boom end you could increase the "stretchiness" of the arrangement so as to help with the broaching issue. Works with shock cord for our jib lead car tackles.
paulk is offline
post #12 of 19 Old 06-21-2001 Thread Starter
I''d lead them to blocks with built-in cam-cleats on each side of the rail. That way I could handle the preventor from both port/starboard, which would be nice esp. in a racing situation.
...Chris
cditzen is offline
post #13 of 19 Old 08-08-2001
the marion bermuda race requires a boom brake or preventer.
in the ocean you will find it is easy to jibe the main even when not running.
the vang tied to the stanchion bases is an accident waiting to happen.
they suggest a line run on either side of the boom from pad eyes on the end of the boom to cleats on either side of the boom at the gooseneck.
then a line is run from the cockpit to the bow with a block at the bow. this line is then run back to either line on the boom connected with a snap shackle.
the lines along the boom enable you to hook up the preventer even if the boom end is outboard. we always hook up the preventer offshore unless we are beating.
eric
kimberlite is offline
post #14 of 19 Old 10-10-2011
So what happens if a preventer is attached in very heavy winds, and an accidental gybe occurs? Does the boat round up violently with complete loss of rudder, then a danger of capsizing?
Without the preventer, an accidental gybe in heavy winds could take out the boom, or any of the rest of the standing rigging. Not good.
marksatterfield is offline
post #15 of 19 Old 10-10-2011
Barquito
Barquito's Avatar
Or knock someones head off (or tear the binnical off etc.). Just as valid now as it was 10 years ago.
Barquito is offline
post #16 of 19 Old 10-10-2011
Working for next Boat
MobiusALilBitTwisted's Avatar
This was about 10 years old it is best to start a new thread not dig up one that is long DEAD.
S/V
1985 Venture 25
Fl Gulf Coast
GrahamO
"Möbius,You need another drink. You are starting to make sense".
MobiusALilBitTwisted is offline
post #17 of 19 Old 10-10-2011
No, the question was what happens if the preventer IS installed? If the preventer is not installed, knocking heads off. If the preventer is installed (and is not let off during a gybe for whatever reason), is a violent round up and knock down eminent?
post #18 of 19 Old 10-10-2011
tdw
Super Fuzzy Moderator
tdw's Avatar
Yeah, it is a bit odd resurrecting a thread this old but it doesn't specifically require an answer or even a response from the OP so no real harm done.
The question of the preventer holding up the main when you do gybe is probably the best argument for using a boom brake. Maybe ?
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #19 of 19 Old 10-10-2011
captflood's Avatar
GREETINGS EARTHLINGS, Ive used a permantly rigged line from the clue end of the boom to gooseneck with a snap shakle this is then can be connected to a line rigged from a srong point froward to use as a preventer and is very quick and easey to change sides when gybeing. REMEMBER SAFETY FIRST ME SECOND. GO SAFE
captflood is offline
Boom Kicker Boom Vang dwottavian Gear & Maintenance 5 01-11-2010 12:48 PM
accidental gybe peter428 General Discussion (sailing related) 23 06-09-2008 07:55 AM
Sail covers for loonnnggg mizzen boom kbennett17 Gear & Maintenance 1 08-06-2002 12:49 PM
Boom Brake KIKO Gear & Maintenance 0 03-17-2002 03:39 PM
Boom Repair? jassing Gear & Maintenance 1 03-12-2001 03:35 PM
