Sail up to reduce rolling? - SailNet Community
Advertise Here
Go Back   SailNet Community > Skills and Seamanship > Seamanship & Navigation
Like Tree3Likes
Old 07-05-2014
EuroboyDC's Avatar
EuroboyDC is on a distinguished road
Good evening!
So, I have what is probably a dumb question. When forced to motor (due to a virtual lack of wind) and being hit by 1-2 foot waves more or less abeam, my Hunter 306 rolls quite a bit. Same if not more so when the waves come from anywhere astern.
Is it my imagination, or is rolling reduced when raising the mainsail and keeping it tight and amidship? Does it act as a sort of "air keel" and provide stability?
Thank you!
Nico
  #2
Old 07-05-2014
RTB's Avatar
RTB RTB is online now
TROUBLE
RTB is on a distinguished road
Re: Sail up to reduce rolling?
Yes it helps. Still sucks....just not as bad as with no sail up in those conditions.
Ralph
New home | sailing away with R & B
S/V FUGUE
HUNTER 36
KEMAH, TX
  #3
Old 07-06-2014
MarkofSeaLife's Avatar
MarkofSeaLife is on a distinguished road
Yes it does help.
Its also quite rare to have absolutly zero apparent wind. Even with just 1 knot of apparent wind the sail will hole the boat quite well compared to no wind at all.
Mark
zeehag likes this.
Sea Life
Notes on a Circumnavigation:
  #4
Old 07-06-2014
Windseeker
theonecalledtom is on a distinguished road
If you can manage your course to get a little angle on the wind it really helps. Put the traveller higher than you would (even boom a little above centre line) and just get a little air in the sail. Comfort vs speed and comfort can be a big factor - these days sailing is generally meant to be fun!
  #5
Old 07-06-2014
Sal Paradise's Avatar
Captain Obvious
Sal Paradise is on a distinguished road
Not only an air keel, but the main can also be an air rudder
Sal Paradise
  #6
Old 07-06-2014
SHNOOL's Avatar
Stupor-user.
SHNOOL is on a distinguished road
I motor sail to save fuel, but you are right, sail up while motoring allows you tighter angles to the wind (because apparent wind comes up)... but also settles the rock and roll a lot.
Can cut fuel usage in half too.
Currently boatless - Everyone's boat is perfect, except the $10,000 in rigging it requires to get it fully functional again.
  #7
Old 07-06-2014
Jeff_H's Avatar
Moderator
Jeff_H has a spectacular aura about Jeff_H has a spectacular aura about Jeff_H has a spectacular aura about
But flogging a sail can really shorten its life quite quickly. It is the worst thing you can do to a sail.
theonecalledtom and zeehag like this.
Curmudgeon at Large- and rhinestone in the rough, sailing my Farr 11.6 on the Chesapeake Bay and part-time purveyor of marine supplies
  #8
Old 07-06-2014
zeehag's Avatar
snake charmer, cat herder
zeehag is on a distinguished road
here in too much or tool ittle windville, i use my jib and mizzen for similar results. and i prevent the one with r'°the boom so as not to kill my pooor old boat.. when i use main i always prevent it .....usually to 2 points.....no flogging boom.. keep flogging on main to minimum
formosa 41 and ericson 35mII
cruising tropical mexico at present, working my way southward
  #9
Old 07-07-2014
EuroboyDC's Avatar
Thank you all! I came across a similar situation again yesterday, and it really does work wonders. Not 100%, of course, but enough so to obviate the need for too much mopping during and after the trip. :-)
Cheers!
  #10
Old 07-23-2014
dabnis is on a distinguished road
We used to fish out of our Coronado 25 in open ocean waters off of San Francisco. Often there was little or no wind but large chop & swell. The boat would roll a lot at trolling speed. We tried putting up the main but it banged around somewhat even with the main sheet tight. IIRC, it helped a small amount, but not enough to matter much. We finally gave up putting the sail up when trolling. When running at hull speed with the sails down,
the boat settled down pretty well and did not roll nearly as much a when trolling.
Perhaps you could do some comparative trial runs with the sails up & own?
Paul T
You may post attachments
You may edit your posts
Extra Rail Meat or Reduce Sail? Zac Penn General Discussion (sailing related) 5 10-05-2013 03:04 PM
Rolling furling head sail for R26. Please Help jaybird2719 Ranger 4 09-08-2013 10:32 AM
Sail Trim: Minimizing rolling in sloppy seas Remittance Seamanship & Navigation 9 07-02-2013 10:26 AM
Reduce Heeling newinthewater General Discussion (sailing related) 24 07-02-2010 06:14 PM
Rod rigging to reduce corrosion ? SvenG Sailboat Design and Construction 17 01-06-2009 07:43 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
