Anchoring in lake weeds - SailNet Community
 1Likes
  • 1 Post By SuperV
post #1 of 8 Old 07-06-2014 Thread Starter
Have a Danforth that will not set and hold in our big weedy lake. What do you all recommend?
seltten is offline
post #2 of 8 Old 07-07-2014
Re: Anchoring in lake weeds
a plow. My solution was a Manson Supreme
Multihullgirl is offline
The Following User Says Thank You to Multihullgirl For This Useful Post:
seltten (07-30-2014)
post #3 of 8 Old 07-07-2014
Old as Dirt!
svHyLyte's Avatar
Take a look at (click on) the Grapnel Anchor that can penetrate through weed.
svHyLyte is offline
The Following User Says Thank You to svHyLyte For This Useful Post:
post #4 of 8 Old 07-07-2014
Interesting - when I tried it, my Manson Supreme would not hold in weeds, nor would my CQR. The other two anchors I had on board were a 150lb Fisherman and an aluminum Fortress. I was sure the Fisherman would hold but since it is a pain to haul out and assemble (really bought for super heavy wind use), I tried my Fortress and it held. Maybe the difference here is how much chain you have. My rode is all chain and I made sure I had plenty scope. Anyway, anchoring seems to be like religion and politics. I am sure before long you will have seen every possible combination suggested. It may be best to see if you can borrow different types of anchors, make sure you have enough chain scope and try them all out to see what works best for your boat and situation.
Multihullgirl likes this.
SuperV is offline
The Following User Says Thank You to SuperV For This Useful Post:
post #5 of 8 Old 07-07-2014
Bristol 45.5 - AiniA
A Danforth is probably about the worst since it has so much surface area for the weight. Beyond the anchor, a really important consideration is the technique. You want to not be moving at all so the anchor and chain can work down through the weed without picking up too much of the vegetation. If you are moving in any direction the anchor gets clogged with week before it even has a change to find the bottom.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
The Following User Says Thank You to killarney_sailor For This Useful Post:
post #6 of 8 Old 07-08-2014
If you're looking for a lunch hook, or something that you'll tend to, I like the grapnel idea. I would not sleep on one or leave for shore, however.
Grass is just an unreliable anchorage, no matter what. Even in the best circumstance, you may actually be set in a big knot of grass that you dragged a few feet and piled up. A few hours later, the grass lets go and you're loose.
We have a few anchorages with heavy grass, such as CuttyHunk. We will try to move around to find a gap or less grass, even if it means anchoring a bit further from shore, in deeper water or less protected from wind/waves. I would rather have a good set in a tough spot and than bad set in a good spot.
Jeanneau 54DS
Minnewaska is offline
The Following User Says Thank You to Minnewaska For This Useful Post:
post #7 of 8 Old 07-08-2014
4KSB driver.
SHNOOL's Avatar
Dock
I'm going to go out on a limb here, and ask the obvious questions... so shoot me if this is too obvious (I am not trying to bust)... But do you have enough rode out? 5 or 6:1 at least? Do you have a decent amount of chain?
On my rather rocky lake in the few places that are soft/weeds, my danforth holds fine, but I use nearly 100 feet of rode, and 10 feet of chain for 15-20 feet of water. I've not had an issue with hold since I've upped the length of my chain from 6 feet. Granted we rarely have high winds, and most of our chop is produced from antique V6 outboards by wanna-be water-drag racers.
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
The Following User Says Thank You to SHNOOL For This Useful Post:
post #8 of 8 Old 07-08-2014
If you have no current and light winds, all you really need to do is drop enough weight. Anything will work.
Jeanneau 54DS
Anchoring in Lake Huron: The harbour master suggested low-tech... JordanH Seamanship & Navigation 7 06-17-2011 07:58 AM
Dragging a MacGregor 22 out of the weeds MikeLatiolais MacGregor 34 03-08-2011 12:23 AM
Anchoring in Western Lake Erie dcott Cruising & Liveaboard Forum 1 07-02-2009 09:43 PM
Coolant Intake, Weeds and Strainers SEMIJim Gear & Maintenance 13 10-08-2007 03:59 PM
Flossing for Weeds Dan Dickison Gear and Maintenance Articles 0 07-05-2001 08:00 PM
