Bad compass? - Page 3 - SailNet Community
 3Likes
post #21 of 31 Old 08-06-2014 Thread Starter
Re: Bad compass?
When I screw it to bulkhead card was reacting on screwdrivers magnetic tip.
Andrew
Born to sail, forced to work.
motogon is offline
post #22 of 31 Old 08-06-2014
Delta-T's Avatar
Re: Bad compass?
I found this info interesting on Natural and Artificial Magnetic Anomalies:
http://prntscr.com/4a7jhf
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
post #23 of 31 Old 08-06-2014
Delta-T's Avatar
Re: Bad compass?
If there were a Natural and Artificial Magnetic Anomalies then other compasses would be affected...easy enough to rule out, any other compasses handy and are they working correctly?
Eric
Delta-T
Delta-T is offline
post #24 of 31 Old 08-06-2014
Re: Bad compass?
if your compass card reacts to the steel screwdriver, i'd say you have an adjustment/calibration problem, not a mechanical problem with the jewell. It's kind of difficult to describe without a visual but imagine: the compass card is a circle and it needs to be in "sync" (not the best term) with another circle (the magnetic field). you use a set of magnets or ferrous parts to bring the two circles such that their centers match. they are never quite exact which is why when you have a compass professionally adjusted, you will get a "deviation" chart which is unique to every compass on every boat. it is also why the degree of deviation will be different with each magnetic heading.
you can use a hand-bearing compass or an orienteering compass to roughly calibrate. you can also use a gps either set to magnetic or with variation taken in to consideration as long as you are moving while you adjust and there is no influence of wind or tide.
Your Danforth compass looks a lot like the Plastimo "Contest". I highly doubt that Danforth make this compass. Do take a pic of the back of the compass so we can all see where adjustments may be made. there should only be two adjustments. One for each axis.
hangupndrive is offline
post #25 of 31 Old 08-06-2014 Thread Starter
Re: Bad compass?
There is two screws. One right under "0" at bottom on compass. Another one on bottom right side off compass.
Andrew
motogon is offline
post #26 of 31 Old 08-06-2014
Re: Bad compass?
Here's why I couldn't find the calibration/compensation/swing procedure:
Danforth are bulkhead mount compasses originally made by the Aquameter Co.. When ITT purchased the Aquameter Co. the Saturn was manufactured by Rule Industries and sold as part of the Danforth Compass line. The Saturn compasses were discontinued in 2009. This compass was not a repairable compass, it was permanently "glued" together and cannot be disassembled. If your compass has an air bubble or the card is tilted at an angle the only choice is to replace the compass.
It does not say that it "isn't adjustable". Here's what I would do: the two screws are likely the adjustment screws. one is for north/south, one is for east/west. When you're faced north, adjust the bottom right screw (I think). When you're faced east or west, use the screw on the front. I think you can tinker with it at the dock to see if it will work then once you get the hang of the adjustment, grab another person and do it properly on the water.
Here is the procedure from the Ritchie website. I know, different make but they all work essentially the same way.
https://www.ritchienavigation.com/me...structions.pdf
Keep us posted
post #27 of 31 Old 08-07-2014
Re: Bad compass?
Once you've got it swinging and can adjust it, Get out on open water,no wind or current. Using a GPS course 0 degrees adjust screws (mini Bishop's Balls) to match as close as possible. Change course E 90 do it again and so on ,'boxing the compass' Smaller increments as you get the hang of it. Finally go around again and record the errors (+ and -)on a paper. Start at N and then each cardinal point on a line from 0 to 360 The recorded points should form a regular shaped sinusoidal wave. This is your error card info. Gps set to magnetic of course.
Capt Len is offline
post #28 of 31 Old 08-07-2014
Re: Bad compass?
Ah, very good!!! We used to put a float in the water & run up & down in all directions. Was never quite sure what my Dad was doing? He said he was boxing the compass. We managed to stay off the rocks, so I guess he did know what he was doing?
Paul T
dabnis is offline
post #29 of 31 Old 08-08-2014 Thread Starter
Re: Bad compass?
Showed compass to guys in marina, verdict: junk, return it if you can, if not garbage can is right there.
GMFL and Delta-T like this.
Andrew
motogon is offline
post #30 of 31 Old 08-08-2014
Re: Bad compass?
Not surprised from what I read about that model. Even still, kind of anti-climactic!
Got it bad, sooooo bad uncleated Introduce Yourself 2 08-16-2013 08:24 PM
Free O Day - How bad is too bad ? ? ? nogin General Discussion (sailing related) 52 03-20-2011 09:40 AM
Compass Maverick1958 Gear & Maintenance 7 01-15-2010 09:01 PM
Compass 28 Classic30 Boat Review and Purchase Forum 32 05-27-2008 02:22 AM
The Compass RickBowman General Discussion (sailing related) 2 12-04-2007 11:25 AM
