Through Hulls - Open or Closed? - SailNet Community
post #1 of 13 Old 05-30-2015 Thread Starter
I am vigilant about closing through hulls when they are not in use. Seems like prudent seamanship to me given that a hose or clamp issue could/can sink a boat. One exception is the engine raw water intake (double clamped I might add) which I occasionally leave open at night in case the engine needs to be started in a hurry. Granted we sail a Catalina 27 so only have 6 through hulls. Some of our through hulls are a pain to reach. The Admiral thinks I am overly concerned and she is not a fan of having to remember to open and close them when she uses the sink.
I recommended that we let sailnet resolve the disagreement. Thoughts on the issue?
Josh
engineer_sailor is offline
post #2 of 13 Old 05-30-2015
djodenda's Avatar
Re: Through Hulls - Open or Closed?
I'm on your side, John.. I close them when I am off the boat for more that a few hours.. Keeping them moving keeps them from getting stuck in the open position too.
David
1987 CS 36 Merlin "Kyrie"
djodenda is offline
post #3 of 13 Old 05-30-2015
I know where they all are, and check them every few months, but honestly I have never closed them regularly. If I was that worried about them failing I would replace them.
Is it safer to close them? Possibly a little, but the skin fitting failures I have seen in the past are not in the ball or after it, but when the pipe broke free from the flange (four of these failures so far). If I was leaving the boat unattended for months I would close them, but our boat is used at least once a week, normally more, and I can't see the point.
In the same vein, it is actually safer to turn off the breaker on your house every time you leave it, turn off the mains water, and shut off the glass valve too. But anyone who did this for their house would be thought of as completely mad. Why it's different on a boat I have no idea.
Greg
Stumble is online now
post #4 of 13 Old 05-30-2015
Chastened
Ajax_MD's Avatar
It's different because your house doesn't sink at anchor and leave you swimming.
Even if you rupture a pipe in your house in the middle of the night, you can walk outside, or shut other valves if you get to them in time.
Ajax_MD is offline
post #5 of 13 Old 05-30-2015
I close mine every time I leave the boat for the day, but leave them open while we're there. We're on a mooring, so if she did sink it's straight down in 30 feet of water. In a slip she'd be hanging on the dock lines in maybe 10 feet of water, so not as critical. Underway, we leave them open. I have a high water alarm so I figure we'd have time to fix the leak if we were aboard.
We do the same thing on my commercial boats, everything on and operational when crew or passengers are aboard, everything but alarms and bilge pumps off when we're not.
capt jgwinks is offline
post #6 of 13 Old 05-30-2015
The only reason to close them while you are away is to limit property damage. Same for the house when you are away. If you are this concerned about the state of your wiring in either place then fix it.
At the marina we turn off the breakers because we have known voltage spikes due to dock wiring that is faulty. But if the delivered power was clean I would probably leave all the breakers on, just like I do at home when I leave for vacation.
Greg
post #7 of 13 Old 05-30-2015
I have cut the handle on a ball valve, and welded them back on at a 45 degree angle,. That way, 45 degrees one way is closed and 45 degrees the other is open. That let me put a push rod on, whatever length is needed, to open and close them in hard to reach spots, without having to reach around lockers full of stuff. Makes it much easier to close and open them.
Peaceful compromise!
Brent Swain is offline
post #8 of 13 Old 05-30-2015
We keep the seacock closed unless we are using it.
"Pegu Club"
1977 Bristol 29.9
cthoops is offline
post #9 of 13 Old 05-30-2015
hpeer's Avatar
Closed when we are off the boat for a day.
I just replaced all six (excepting the engine which is a special case). I went with Forespar series 93 because I view them as stronger, mounted right to the backer plate, it sticking up. Also they can be serviced. I actually moved one to make it easier to get at and oriented 4 all the same way, easier to remember how to operate them.
A while back a nice steel boat was lost after a roll In large part because she took on sufficient water to put the sink under the water line. The owner had a knock on the head and was incapacitated. The crew could not find and operate the sea ****. She sunk through the sink! How painful is that?
hpeer is offline
post #10 of 13 Old 05-30-2015
hpeer's Avatar
I just replaced all six (excepting the engine which is a special case). I went with Forespar series 93 because I view them as stronger, mounted right to the backer plate, not sticking up. Also they can be serviced. I actually moved one to make it easier to get at and oriented 4 all the same way, easier to remember how to operate them.
A while back a nice steel boat was lost after a roll In large part because she took on sufficient water to put the sink under the water line. The owner had a knock on the head and was incapacitated. The crew could not find and operate the seacock. She sunk through the sink! How painful is that?
hpeer is offline
Open or closed seacock? cthoops Gear & Maintenance 23 05-03-2013 07:03 AM
Through-hulls closed in winter? cghubbell Gear & Maintenance 7 10-07-2009 01:12 PM
Seacocks Open or Closed when Away from Boat DrB General Discussion (sailing related) 22 05-01-2008 10:45 PM
Closed vs Open body turn buckles Wayne25 Gear & Maintenance 8 12-06-2007 11:29 AM
Open vs Closed turnbuckle bodies bsfree Gear & Maintenance 4 04-24-2002 09:25 AM
