Anchorage near C & D canal - SailNet Community
 2Likes
post #1 of 11 Old 09-26-2015 Thread Starter
Will be leaving boat show and want to spend night before entering canal. Boat draws 7.5'. Recommendations? Thanks
Wavehiker is offline
post #2 of 11 Old 10-01-2015
Re: Anchorage near C & D canal
The Bohemia river area has an anchorage that's good for waiting out favorable currents. There are some shoals though that could be something to watch out for with your draft.
jtulls is offline
post #3 of 11 Old 10-02-2015
The most female moderator
Donna_F's Avatar
Dock
If the weather isn't bad there's an acceptable anchorage in front of Worton Creek.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #4 of 11 Old 10-02-2015
RichH's Avatar
The Bohemia R. is NOT a place for a 7.5ft. draft.
Most boats w/ 6ft. drafts transiting to the Marinas on the Bohemia usually/recently have to wait for high tide; plus, with the gales/hurricane now offshore producing northerly and/or north-easterly winds --- such typically will LOWER the water level in the Upper Ches. (and LOTS of westerly flowing water in the C&D Canal, especially when the Del. River -use Reedy Point as your tide benchmark station- is at full flood).
For a staging point close to the C&D, and with N-NE winds, Id 'risk' anchoring on the outside of the mouth of the Sassafrass River (west of Ordinary Point) & just east of Grove Point (north shore of Sassf.) and tucked under one of the cliffs (watch out for boulders close to shore when near the cliffs, especially towards the bay) or close in using the tree line as your wind break.
Ditto the same with anchoring on the N-NE side (cliffs) of Still Pond.
Both of these 'outside' areas should NOT be used to anchor when there are greater than 'gentle' W-NW winds in the forecast.
The entrance to Worton Cr. (my home port) is OK for anchoring (not in a W-NW'er); but, its about 2.5 hr. from the C&D. Sassafras R. @ 1 hr., Still pond about 2 hrs. to the C&D.
RichH is online now
post #5 of 11 Old 10-03-2015
TakeFive's Avatar
What about Engineer's Cove in Chesapeake City? It's only about an hour past Bohemia. I haven't been in there in a couple years, so not sure the status of shoaling vs. dredging for a 7.5 foot draft. Over Labor Day weekend I did notice that they have new markers encouraging traffic to stay on the east side of the entrance.
From a couple years ago, I'd say it's too shallow for 7.5 foot draft, but if someone knows of more recent dredging it might be doable, so I'm just putting it out there for others to comment on.
I guess one other option that is definitely doable is a slip at Shaefer's Canal House, though it will cost $$$ and have a LOT of current.
Maybe he could try Engineer's Cove for free anchorage and if it's too shallow to get in or too crowded, then head over to Shaeffer's for a slip as a backup plan.
Rick S., Swarthmore, PA
TakeFive is offline
post #6 of 11 Old 10-03-2015
What TakeFive wrote;
Last time I was in Engineers Cove, Chesapeake City this July there where at least 3 sail boats over 40ft, one at the town dock and two in the anchorage.
I draw 4ft so never a problem for me.
Depth sounder showed at least 10ft at the entrance with 5ft at the end of the dinghy dock. When the free town dock is full (at least 9ft depth) I use the free slips posted as "end of dredging".
Inside the canal is well illuminated with yellow sodium lights, and an easy approach even after dark from Turkey Point with marked channel lighted buoys and range lights.
Plan your transit using current not tide as the current change is out of phase with high and low tide.
1970 Havsfidra 20 by Fisksatra
On the Delaware River at Fox Grove Marina Essington PA
Ulladh is offline
post #7 of 11 Old 10-04-2015
Donna_F's Avatar
Dock
I thought of engineer's cove and that maybe the depth might be a bit risky for a 7'6" draft. If there are a lot of boats in the cove, which is possible this time of year as snowbirds stop on the way down, then he's sort of screwed.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #8 of 11 Old 10-04-2015
TakeFive's Avatar
A few years ago he would have been screwed. With Shaefer's reopened with slips for rent, he'd merely be out a few dollars. That could make it an acceptable risk, given that there's not much else up that far for his draft.
TakeFive is offline
post #9 of 11 Old 10-04-2015
RichH's Avatar
The latest (9-24-15) advisory from Active Captain for the entrance to the Engineers Cove at Chesapeake City on the C&D ... has the depth at 7' MLW ..... meaning that he'll ground out with a 7.5ft keel depth.
The east side of the entrance along the east bulkhead and 20 ft. off the bulkhead is now the preferred route in ..... but requires precise following of the buoys inside. No further info on the depths on the 'inside'. Check the Active Captain website for full details.
RichH is online now
post #10 of 11 Old 10-04-2015
TakeFive's Avatar
Originally Posted by RichH View Post
The latest (9-24-15) advisory from Active Captain for the entrance to the Engineers Cove at Chesapeake City on the C&D ... has the depth at 7' MLW ..... meaning that he'll ground out with a 7.5ft keel depth...
...if he goes in at MLW. A quick look at tide tables or wxTide predictions shows that he could find a window to get in/out unless there is an extreme weather event that lowers the water level. And if that happens, there is still Shaefer's Canal House on the north side.
One comment about the new markers there: during the times that I passed the cove this summer, EVERY SINGLE stinkpot I saw went in to the west of the red marker. It's as if they thought it was marking the center of the channel. I was wondering if I would see one of them run aground.
TakeFive is offline
C&D Canal reopens after sailboat crash - Centre Daily Times NewsReader News Feeds 0 05-19-2007 10:15 AM
C&D Canal reopened following sailboat crash - NEPA News NewsReader News Feeds 0 05-16-2007 10:15 AM
C&D Canal reopened following sailboat crash - Centre Daily Times NewsReader News Feeds 0 05-16-2007 09:15 AM
C&D canal closed after tug, sailboat collide - Baltimore Sun NewsReader News Feeds 0 05-14-2007 06:15 PM
Sailboat sinks after colliding with tug in C&D Canal - The News Journal NewsReader News Feeds 0 05-14-2007 03:15 PM
