What to do if my slip runs dry - Page 3 - SailNet Community
post #21 of 49 Old 11-09-2006
moderate?
camaraderie's Avatar
how's a deck full of earwax sound?
most enjoyable with a nice glass of chianti!!
camaraderie is offline
post #22 of 49 Old 11-09-2006 Thread Starter
Since you asked about the lake...
Lake Hefner is a 2500 acre reservoir in NE Oklahoma City. It provides water for OKC. I am in the municipal slips(fix concreate piers) that are managed by the city on the west side of the lake, but there are no real marina services. There is a OKC Boat Club with floatig slips on the east side of the lake. The water level is controlled by a Water Trust that owns water in several other reservoir around the state and can let water down rivers and cannels to maintain the water level in the lake.
The lake is a good sailing lake because it a high local evation so the winds are alwasy pretty good.
Over the last few years we have have pretty sever dought conditions. This over the last 18 month we are about 19 inches below normal. So both the level in the lake and the supporting reserviors are very low.
Currently the lake is droping about 9 inches a week unless we get a little rain and then it might be only 6 inches. At this point the lake is down 8 ft or so.
This week they closed all the ramps to the lake.
We are in a pretty sad situation at this point. It is unlikly there will be a significant change until spring.
dbnorth is offline
post #23 of 49 Old 11-09-2006 Thread Starter
Thanks for the ideas.
How much of the weight of the boat should be supported by the legs vs. the keel? (I have a swing keel).
dbnorth is offline
post #24 of 49 Old 11-10-2006
Dbnorth-
The amount of weight you put on the swing keel depends on the design. If the swing keel is essentially a weighted centerboard, that swings up in to a keelstub and trunk, then with the board retracted, you should be able to rest the boat on the keelstub and just use the legs for balance.
sailingdog is offline
post #25 of 49 Old 11-10-2006 Thread Starter
My boat is a 1977 Catalina 25. I do think the swing keel is like a weighted center board that swings up into a small trunk but from the pictures I have seen it does not swing all the way in ther is still 12 inches or so below the boat.
dbnorth is offline
post #26 of 49 Old 11-10-2006
Dad, the only thing I'll be waxing is poetic for a couple of days...
but, I've been told by the Cuban that if I get the laundry done, I can go sailing today. heheheheh.
We are not primarily on earth to see through one another, but to see one another through
Some people are like slinkies: not really good for anything... but you can't help laughing when you push them down the stairs
cardiacpaul is offline
post #27 of 49 Old 11-10-2006
moderate?
dbnorth...We're all still wondering how you got theboat into the slip and why you can't take it out the same way.
Anyway...with the swing keel on the Catalina...you need to get the entire weight of the boat on the jack stands. You can place a timber underneath the aft end swing keel and let that take the weight of the dropped keel by slacking off on the lifting pendant.
post #28 of 49 Old 11-10-2006
I see the Cuban is the boss in your household CP... she has her priorities straight at least.
post #29 of 49 Old 11-10-2006
sailortjk1's Avatar
dbnorth,
I really can't believe that you are still thinking about leaving your boat in.
Get out while you can. If its dropping 9 inches a week your going to be on the bottom very soon. Its probably dropped 5 inhches since your first post.
How much good quality sailing do you expect to get in over the winter?
But hey what do we all know, we are not in your shoes.
If it were me I would raise that retractable keel and get myself somewhere where I know my boat will be safe.
I know its bit expensvie, but could you not haul your boat for safety purposes than relaunch when all is clear? Just something to think about.
Best of luck.
sailortjk1 is offline
post #30 of 49 Old 11-11-2006 Thread Starter
As far as how the boat got in the lake. I bought it last summer and it was in the slip. I think the previous owner had it hauled to the lake about 4 years ago and I don't think it has been out since them. Unfortunatly I don't have a trailer for it.
dbnorth is offline
Have 37'Endvr with liveaboard slip in Daytona firemanbob55 Living Aboard 0 10-20-2006 02:28 PM
Dry Sailing vs. Not Dry Sailing nroose Racing 2 01-21-2003 06:20 PM
Dry Sailing vs Not Dry Sailing nroose Learning to Sail 6 01-02-2003 06:16 PM
Displaced weight vs Dry Weight mikehoyt Gear & Maintenance 7 10-23-2002 05:01 AM
Slip Width johar General Discussion (sailing related) 7 09-27-2002 09:46 AM
