Towing a dinghy - Page 6 - SailNet Community
post #51 of 58 Old 02-08-2007
T37Chef's Avatar
Originally Posted by T37Chef
The system looks sturdy just didn't like the idea of leaving the motor on in the stored position.
PB...I got that. Still looks weird to me But then again...I'm weird.
Shawn
T37Chef is offline
post #52 of 58 Old 02-08-2007
Best Looking MALE Mod
Cruisingdad's Avatar
Giu,
I am buying me one of those!! That ISSSS my idea of racing. Sweet!! I think that new 300hp yamaha max ought to do it.
Cruisingdad is offline
post #53 of 58 Old 02-08-2007 Thread Starter
Wandering Aimlessly
PBzeer's Avatar
CD - don't forget the retracting hydrofoils under the boat.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
PBzeer is offline
post #54 of 58 Old 02-08-2007
PB,
I have a wing keel. Hydrofoils... check. Need I say more!??
post #55 of 58 Old 02-08-2007
Chief Cook & Bottlewasher
Send a message via Yahoo to stagew8t
towbar augmentation
Originally Posted by T34C
If you need a solid "towbar" try running the painter thru a peice of small pvc pipe. It works well as a stand-off for the dink.
To help cut down wear and tear on your dink with that PVC towbar, use the PVC epoxy for bonding the pipe to a flange on the dink end of the pipe. That should help spread out the force of the bare end poking into your dink. You can add to the cusion factor by adding some closed cell neoprene to the flange. The closed cell material won't absorb any water to make for a wet storage issue when you're done with the towbar. Wetsuit material works great and most SCUBA shops will probably have some around. Alternatively for that extra cushion, cut holes in a tennis ball or two and thread the painter through them.
stagew8t is offline
post #56 of 58 Old 02-08-2007
Most outboard motors do have a problem with being stored on their side or inverted... so I don't know if I'd be all that happy about using the dinghy tow with the outboard motor inverted like that.
sailingdog is offline
post #57 of 58 Old 02-19-2007
Here .. Pull this
"I have a 8' Walker Bay rigid dinghy that I plan to tow unless offshore. Question is.....how far back do you let it ride? Secondary question is, how wise is it to leave the outboard on the dinghy while towing?"
Depends on whether or not you have the wife sitting in it. If she is - then you'll want to make sure she's far enough back that she misses when she starts throwing things at you. And you'll probably want to make sure that you don't leave her the motor in case she high-tails it back to shore. If she isn't in it then about two boat lengths is usually good.
Sailormann is offline
post #58 of 58 Old 02-19-2007
Here .. Pull this
Dinghy lengths that is...and use a bridle
Dinghy boarding ladder Bruceo1 Gear & Maintenance 10 02-07-2007 03:02 PM
Stowing Hard Dinghy on 30ft boat, opofcabo Provisioning 4 11-22-2004 02:47 AM
Towing hard dinghy EClaire Gear & Maintenance 3 04-24-2003 08:47 PM
Dinghy Trailer mizzen2 Gear & Maintenance 0 04-10-2001 12:40 PM
Nelson Sailing Dinghy sailboatshark General Discussion (sailing related) 0 12-08-2000 02:03 PM
