Sheet Bend - SailNet Community
 14Likes
post #1 of 35 Old 2 Weeks Ago Thread Starter
davidpm's Avatar
Sheet Bend
We are still required to teach the sheet bend as part of one of our classes.
I've never used it in real life, however.
My thinking is that if you need the sheet bend you need a long line that you don't have. Right there I consider that some sort of failure or at least an issue is at play.
Either the boat was not provisioned properly with lines needed or I got myself into a situation I hadn't anticipated.
In either case, I wouldn't trust the sheet bend. It looks like it could shake loose too easily.
I know I could use a double sheet bend but what I usually do is use a bowline to bowline. Yes, they can shake out too but if I'm worried I can add a hitch to the tail.
One possible reasonable scenario is when docking or webbing your boat by tying it with long lines to the shore. Even then I 'm not sure I would trust it.
I would like to ask our experienced sailors. Do you ever routinely use the sheet bend? I would like to have an example to give the students where it would be an excellent choice.
As a side note, I never use a clove hitch to attach a boat to a piling. I had one come loose on me.
davidpm is offline
post #2 of 35 Old 2 Weeks Ago
Re: Sheet Bend
Insulting a man's knot is bad manners.
Knots can be personal.
Some people name their knots.
Some knots like to be under tension, while others simply do not care.
Knots have their our special world, which we can visit..and play around a bit.
RichH and olson34 like this.
RegisteredUser is online now
post #3 of 35 Old 2 Weeks Ago
colemj's Avatar
Re: Sheet Bend
I use sheet bends all the time to temporarily attach one rope to another. It is particularly useful when the ropes are of significantly different diameters. Don't know why you consider such usage a failure - why would one go and buy a long length of line just for a temporary use, or why would needing a temporary application be a sign of an unanticipated situation?
On the other hand, the clove hitch is one of my most used knots...
Mark
capta likes this.
Manta 40 Catamaran "Reach"
colemj is offline
post #4 of 35 Old 2 Weeks Ago
overbored's Avatar
Re: Sheet Bend
Got second place in a knot tying contest when I was a kid for tying a left hand sheet bend and an outside bowline. I was way faster but the judge was being picky. I have used the sheet bend to tie a heaving line to a hawser.
capta likes this.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #5 of 35 Old 2 Weeks Ago
Re: Sheet Bend
Sheet bend/double sheet bend is one of my go to knots. I use it pretty well whenever I need to tie two lines together. Extra long mooring lines and long lashings are examples.
It's just so fast and easy to tie, especially if you are using one hand to hold onto a ladder or something.
MikeOReilly and capta like this.
Bay Hen 21, Prindle 16, Walker Bay 8
Arcb is online now
post #6 of 35 Old 2 Weeks Ago
BarryL's Avatar
Re: Sheet Bend
Hey,
I used a sheet bend last week. I bought a new mooring pick up stick stick and needed to tie it to my mooring. I am too cheap to buy a new line for that. I had some scrap line laying in a locker - right diameter, but too short. I used the sheet bend to e two pieces together and there you go.
This line should be part of my mooring setup all season. I'l let you know how it lasts.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is online now
The Following User Says Thank You to BarryL For This Useful Post:
davidpm (1 Week Ago)
post #7 of 35 Old 2 Weeks Ago
MikeOReilly's Avatar
Re: Sheet Bend
Oh man, I couldnít disagree with you more. Sheet/double bend is one of the standard knots I use on board. Probably only exceeded by bowline and rolling hitch. The sheet bend is very secure; the double is even better. I trust it when I go aloft (on my line climber), or to keep my mast up when I have to release the backstay (and extend the halyard).
Completely agree with Arcb; itís fast and easy to tie, very easy to lock in, and very secure. Iíve never had one shake out.
mstern likes this.
Why go fast, when you can go slow.
MikeOReilly is online now
post #8 of 35 Old 2 Weeks Ago
Rainwatcher
Re: Sheet Bend
I think if I needed a knot on my climber, that would be one of the places I'd be willing to buy a longer piece of line, regardless of how many CRB points I'd be giving up.
I use sheetbends all the time.
Black Lives Matter.
Proud to live in a Sanctuary City.
Jammer Six is online now
post #9 of 35 Old 1 Week Ago
Zanshin's Avatar
Re: Sheet Bend
I use the sheet bend all the time to put up my flags; flags typically have a loop on one side a length of line on the other. The loop gets attached to the halyard with a bowline while a sheet bend (I usually use a double sheet bend) does the job on the other end. Very secure if the knot is tensioned before going up the mast and I've never had one slip on me. I also use a sheet bend any time I have lines with different diameters that need to be attached to each other.
Zanshin is online now
post #10 of 35 Old 1 Week Ago
RichH's Avatar
Re: Sheet Bend
Here's my standard for joining lines:
Zeppelin Bend | How to tie the Zeppelin Bend | Climbing Knots
Faster, stronger, easily 'doubled', won't shake loose, an 'official' USNavy knot, etc.
This was one of my go-to's for 'rescue stuff'.
sailordave and JoCoSailor like this.
RichH is online now
The Following 2 Users Say Thank You to RichH For This Useful Post:
davidpm (1 Week Ago), jwing (1 Week Ago)
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
rpludwig
Appropriate mast bend? bshock Gear & Maintenance 7 05-06-2014 07:26 AM
Big Bend ijpratt Florida - Western 3 12-26-2013 11:14 PM
Mast bend? AirborneSF C & C 8 04-09-2013 02:32 PM
mast bend Piratesoul Irwin 0 07-20-2008 06:20 AM
Mast Bend offline2004 Gear & Maintenance 7 02-17-2006 10:50 AM
