gybe preventers - Page 2 - SailNet Community
post #11 of 19 Old 02-22-2007
No you dont tie either on. It just clips on the sheet you are using.
chris_gee is offline
post #12 of 19 Old 02-23-2007
thanks, I hadn't looked at the pole in so long I'd forgotten what fitting was at the end.
Jon
fendertweed is offline
post #13 of 19 Old 03-13-2007
flomaster's Avatar
I use a simplified version of Valiente's preventer. I attach a snatch block forward of the mast on either side of the boat. I'll use my spare jib sheets, if I have nothing else, and tie one end to the boom, lead it through the snatch blocks, and then lead them aft to my two aft winches. That setup, and a whisker pole, makes for a pretty easy run sailing wing on wing.
The double headsail idea isn't too bad, either, if you have an extra halyard up front (you should have a spare, anyway). I just don't like unfurling the extra sail, only to have to stuff it back in the bag later.
flomaster is offline
post #14 of 19 Old 03-14-2007
Valiente's Avatar
That will work fine in all but very heavy air cases, but I add the mechanical advantage in case of a situation that might crash gybe the boom, like weak winds but relatively high following seas, like from a front that's passed over but left a lot of slop behind. That sort of thing can roll the boat enough to turn the boom into a bam.
When sailing very broadly downwind, if I want to gybe/wear the boat smoothly, I'll use both rigged preventers instead of the mainsheet to transit the boom under some friction as I give a little nudge with my knees holding the tiller.
I've just found it's a nice way to handle things alone and I've transferred "the system" to the new, larger boat, although the boom is high enough that it's not half the hazard it was on the 33 footer...and I will have a pretty heavy traveller on the deck as opposed to the cabin top just aft of mid boom.
Valiente is offline
post #15 of 19 Old 04-08-2007
Send a message via MSN to stillanoob
I know that this is a really obvious question to most but what exactly is a preventer and how does it work? Is it a couple ropes there to hold the boom back? or that boom brake? I am way off owning my first real boat, but am looking into getting a 16' Nacra or hobie cat so brushing up on the terms is prolly a good start
stillanoob is offline
post #16 of 19 Old 04-08-2007
A preventer is a line attached to the boom and some point forward on the boat. Its purpose is to prevent the boom from crossing the boat in an accidental gybe and hitting you in the head—hence the name, preventer. Usually, there is one on each side of the boat, and they have to be released and re-tensioned after each intentional gybe.
A boom brake, serves a similar purpose, to reduce the chance of injury from the boom in an accidental gybe, but as it is named, it works by slowing the movement of the boom, rather than preventing it altogether. It is usually a device—essentially a rope clutch of a sort, that is attached to the boom and has a line that is attached forward and outboard of the boom on either side that runs through it. By adjusting the tension of the rope and the clutch mechanism, you can control how much braking force is applied to the boom.
IMHO, a boom brake is a better solution than the preventers, since it requires less user intervention once it is setup than do the preventers. It also has fewer dangers associated with it than do the preventers, which, in certain instances can cause the mainsail to backwind and "pin" the boat down, possibly leading to a capsize situation.
sailingdog is offline
post #17 of 19 Old 04-08-2007
"Quack, damn you."
pmoyer's Avatar
Send a message via AIM to pmoyer
It seems like many of the preventer rigs also require someone to go forward to release the line at the snatch block in the forepeak, prior to any gybe....
No real expience - adjust confidence accordingly!
Cheers!
Phil Moyer
S/V Puddleduck
Columbia 26K
pmoyer is offline
post #18 of 19 Old 04-08-2007
It depends. If you're using a snatch block forward, and the line is long enough, you can have it run aft to the cockpit and just slacken it when you need to gybe. This would avoid the need to leave the cockpit to adjust the preventers, but would leave two more long lines underfoot in the cockpit. If you're sailing with a jib and a spinnaker, now you've got eight lines sitting in the cockpit—not including the mainsheet or any traveler or track control lines.
post #19 of 19 Old 04-08-2007
Newbie
Guesser's Avatar
I'm a bit lazy, so when I'm sailing downwind in in light air I just take the end of a jib sheet (or any handy line) and lash the boom to a stantion or cleat; this generally provides enough protection and keeps the main from floundering about. I also have a 4 to 1 preventer for use in heavier winds, but usually it's overkill and not worth the effort.
On a side note...I recently added a boom kicker and I gotta tell ya, it is the coolest thing ever.
Guesser is offline
accidental gybe peter428 General Discussion (sailing related) 23 06-09-2008 08:55 AM
dip ople gybe ques bkw Racing 9 01-19-2007 08:34 PM
using preventers question jmencel Learning to Sail 15 10-25-2006 12:36 AM
hudson river gybe coondogger Seamanship & Navigation 5 12-26-2005 04:46 PM
Preventers on Wishbone Booms Mark Matthews Gear and Maintenance Articles 0 05-15-2002 09:00 PM
