Navigation problem - Page 3 - SailNet Community
post #21 of 43 Old 02-22-2007
humble pie rat
CapnHand's Avatar
Ok, so this is simpler than I first thought. This is way I should have done it the first time.
First of all, this is the situation. The distance the friend’s boat will travel is 5t (t = hours) NM on a course of 036 Deg T. You are 84NM from him at a bearing of 096 Deg T relative to his boat. In order to meet, you will travel a distance of 7t NM at some unknown heading.
It’s obvious that the angle between the track of your friend’s boat and the bearing from his boat to yours is 96 – 36 = 60 Deg
http://www.sailnet.com/photogallery/...ll=no&dthumbs=
Remember the law of sines? It’s handy. It says that for any triange the ratios of the length of each side to the angle opposite that side are equal.
If A is the angle between the heading you need and the bearing from your boat to your friends,
that means: sin60 / 7t = sinA / 5t
or sin –1 (5/7 * sin 60) = A
A = 38.2 Deg
Your heading then should be 96 + 38.2 + 180 = 314.2 Deg T
How long to get there?
We all remember that the sum of all the internal angles of a triangle = 180 so the remaining angle is 180 – 38.2 – 60 = 81.8 Deg
From the law of sines, 7t = 84 * sin 60 / sin 81.8
t =10.5 hours
There are 10 kinds of people. Those who understand binary and those who don't.
CapnHand is offline
post #22 of 43 Old 02-22-2007
can't re member
Pretty slick! And not a bad way to get thrown out of a cocktail party either!
Now about roller furling......
Really nice job CapnHand.
yotphix is offline
post #23 of 43 Old 02-22-2007
Capt Hand,
Yeah, easy, but I believe confusing on several counts.
First, the friends boat (Vessel #1) is on a COURSE of 036T, not a BEARING. His speed is 5 knots. His distance from your boat (Vessel #2) is 84nm. The BEARING to/from the vessels is ambiguous, the way it was presented. Normally, bearings are taken FROM your vessel, but the wording in the original is ambiguous, as in your solution. Either way, the answers provided do not agree with the computed values. Your boatspeed is 7 knots.
Let's assume that the bearing of 096T was, indeed, from Vessel 1 to Vessel 2. The reciprocal bearing, from your vessel to your friend's vessel, is then 276T.
If we then set up the problem in a conventional way, it looks like this:
Vessel #1 (friends boat): Bearing 276T Distant 84nm Course 036T Speed 5 knots
Vessel #2 (your boat): speed 7 knots
Required: course, time, and distance to intercept
According to the calculator (both of the aforementioned calculators agree):
Course to intercept: 314.21 T
Time to intercept: 10 hours 30 mins
Distance to intercept: 73.5 nm
Bill
btrayfors is offline
post #24 of 43 Old 02-22-2007
First of all, this is the situation. The distance the friend’s boat will travel is 5t (t = hours) NM on a bearing of 036 Deg T. You are 84NM from him at a bearing of 096 Deg T relative to his boat. In order to meet, you will travel a distance of 7t NM at some unknown heading.
A = 38.2 Deg
t =10.5 hours
While I applaud your attempt to answer the question, I see it as seriously flawed.
Given that your distance from his boat is 84NM to start with, and his is moving away from you, and you only move at 7 knots... I don't see how the answer could be 10.5 hours.
Draw the vectors... In 10.5 hours you have gone only 73.5nm on a heading of 73.8˚T. His position has now become 52.5nm @ 36˚T + the original 84NM @ 96˚T in the same 10.5 hours—119NM from your original position, or 45.5NM further along the same heading.
If you assume you were at coordinate (0,0) and have moved to (70,20.5)... boat B's position has gone from (83, -8.5) to (114, 33). You're still nowhere near them... Your solution assumes an interior angle of 60 degrees, but it has an interior angle of 120 degrees (96 -> 36). However, you are on a direct vector to their current position.
sailingdog is offline
post #25 of 43 Old 02-22-2007
dog,
I think his time to get there (10.5 hours) is correct, that is, if you assume that the ambiguous bearing info given is actually the bearing FROM the friend's boat TO your boat, as calculated in my response.
This confusion would not have existed if the original post had been unambiguous and/or phrased in the conventional way (i.e., FROM the maneuvering vessel TO the target vessel).
Bill
post #26 of 43 Old 02-22-2007
True... the wording is somewhat unusual...and makes a huge difference in the calculations.
post #27 of 43 Old 02-22-2007
On a paper chart, plot your friend's DR track out past the time you want to meet, then set a compass to the distance you can make during that same period. Set the compass point on your current position, and strike an arc through your friend's DR track; this is point where and when the meeting will take place, if you steer the course between your current position and there. If the arc does not intersect your friends track, one of your assumptions is unrealistic (speed, etc.). You can adjust for set and drift as you near each other. That's the way I did it thirty years ago, in the Navy, on the bridge.
tmhdgpth is offline
post #28 of 43 Old 02-22-2007
tmhdgpth,
That's a useful technique, but doesn't respond directly to the problem as stated.
This is because there is no fixed time (time desired) for meeting. Rather, the desired meeting time is the EARLIEST time possible, given the relative positions of the vessels, the (fixed) course of one of them, and their respective speeds.
It's a classic intersect problem used in war gaming and targeting, as well as air and maritime navigation. Maneuvering Boards were the classic way to solve the problem, and a few brave souls used trig, but now calculators and computers make it easy.
Regards,
Bill
post #29 of 43 Old 02-22-2007 Thread Starter
Courtney the Dancer
jrd22's Avatar
I'm impressed with all the effort that has gone into solving this. I apologize for the ambiguity in my original post. I meant the relative bearing TO the other boat (friend)was 096T, but did not make that clear. The actual USCG question uses different courses, I was looking for the method, not an answer, and if I understood trig better (at all?) I think you guys have done it. The testing is multiple choice with four possible answers given. The answers only vary by 2-3 degrees each so you have to be right on. In the actual test nothing except a simple calculator, plotter, parallel rule, dividers and a pencil are allowed. By the way, the CG has a data bank of 14,000 total questions, (Navigation General, Rules of the Road, Deck General, Navigation problems) and I am working my way through all of them(lot's of duplicates). Thanks again for all the help and ideas. If I come across something else that stumps me I'll post it. Now, back to how many round turns to put on a bitt before figure eights using nylon line:-)) John
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #30 of 43 Old 02-22-2007
The more I read, the easier the maneuvering board solution seems to be.
Goodnewsboy is offline
Working With the Stars—Celestial Navigation Jim Sexton Seamanship Articles 0 05-06-2003 08:00 PM
Working With the Stars—Celestial Navigation Jim Sexton Her Sailnet Articles 0 05-06-2003 08:00 PM
Navigation Basics Jim Sexton Learning to Sail Articles 0 01-04-2002 07:00 PM
Navigation Basics Jim Sexton Seamanship Articles 0 01-04-2002 07:00 PM
Navigation Basics Jim Sexton Her Sailnet Articles 0 01-04-2002 07:00 PM
