Jammed Furler - Page 4 - SailNet Community
post #31 of 44 Old 03-27-2007
Amen to that Stan... definitely like the new Spectra-based lines for halyards... stronger than wire, lighter than rope, with about the same stretch as an all wire halyard.
TB- Have fun... hope it is a windless day when you go up...
sailingdog is offline
post #32 of 44 Old 03-27-2007
All my halyards and working rope is Dyneema...all of it...zero stretch, very lightweight...I am happy with it..why don't you guys use it also?
http://www.roostersailing.com/mercha...egory_Code=dyn
Giulietta is offline
post #33 of 44 Old 03-27-2007
Giu-
Spectra, dyneema...basically six of one, half-dozen of the other... very similar in characteristics... both are forms of ultra-high-molecular-weight polyethylene... and it does stretch, about 1-1.5% depending on what rope it is, and the construction method.
post #34 of 44 Old 03-28-2007
Larus Marinus
Idiens's Avatar
Originally Posted by christyleigh
get rid of it
Yes Sir! It is done! The sheaves seem happy too. Hope Giu is right about Dyneema.
Idiens is offline
post #35 of 44 Old 03-28-2007
Off course I am...I have all my ropes in Dyneema...its light and strong...just remember if you can, have the 2 diameter system, where all the light thin rope goes up the mast, all hand contact rope with thicher section.
Even my back stay is 100% dyneema...all of it..
Everything that goes up is lower diameter dyneema, including all 6 halyards.
The back stay also, from mast top to inverted V and inside stern purchases (2 of them).
Then once it goes to your hand, it goes to a larger diameter, but still dyneema.
I like it a lot...
post #36 of 44 Old 03-28-2007
Larus Marinus
Idiens's Avatar
So far I only have a couple of Dyneema/Spectra lines on board, one is spliced onto a much thicker line for handling. I have to learn how to do that splicing trick. Being a poor cruiser, I worry about UV weakening the lines, so the first two are a bit of an experiment, but I'm not going back to wire. I have a colleague in the club who has his entire rigging in fibre.
Idiens is offline
post #37 of 44 Old 03-28-2007
Yes..the UV may be a problem...but not that serious..I believe you're in Europe, right?? I am in the hottest/sunniest country in Europe and years go by before I need to replace them..you're OK..Besides, I only replace the outside lines..all the inside mast are normally ok
post #38 of 44 Old 03-28-2007
Larus Marinus
Idiens's Avatar
Hotter and sunnier than Brussels? Impossible
Idiens is offline
post #39 of 44 Old 03-28-2007
Are you kidding me??? or are you serious???
post #40 of 44 Old 03-28-2007
Larus Marinus
Idiens's Avatar
We bathe in the light of the European Commission who still surround themselves with white-hot technology.
Brussels - land of the mid-night solarium.
Idiens is offline
In-mast furler; to buy or not to buy; GreggRuch Boat Review and Purchase Forum 55 04-25-2011 06:40 AM
Roller Furling Lay Up Tom Wood Gear and Maintenance Articles 0 10-21-2003 08:00 PM
