Knots(the rope kind) - SailNet Community
post #1 of 5 Old 04-18-2007 Thread Starter
Courtney the Dancer
jrd22's Avatar
Don't know if this site has been posted here before, but in case it hasn't, here it is. Animated pics of most knots you need, pretty neat, you can view each stage or watch the whole sequence. You can buy the CD so you can take it on the boat with you
Animated Knots by Grog
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #2 of 5 Old 07-29-2007
Back to just the Jon boat
therapy23's Avatar
Thanks.
Nice site!
I did see this though.
"Overboard: The Rolling Hitch has been promoted as the only knot to tie in the following unlikely but critical circumstance: while sailing alone you fall overboard and catch hold of the line which you have prudently left trailing astern and find yourself hanging on with difficulty. Before you tire, you manage to bring the bitter end of the rope around your back. You then have to tie a suitable knot to make a loop around you. A bowline cannot be tied under load. Two half hitches will slide and constrict you. The Rolling Hitch is the answer. Even as the second turn is tucked "up" into the correct place, the major strain is taken and the final half hitch can be tied with less urgency."
here - http://www.animatedknots.com/rolling...ww.sailnet.com
Not true. I can do it easily and quicker than the rolling hitch I believe.
I do not have a video and it would be hard to explain in text - for me anyway.
therapy23 is offline
post #3 of 5 Old 07-31-2007 Thread Starter
Courtney the Dancer
jrd22's Avatar
I guess it would depend on how much of a load the line was under. I've managed to tie a bowline in a lot of unfavorable situations, but being towed in the water at 5 knots makes me wonder if I could do it. My first choice would be a bowline because I'm so familiar with it and can do it "blind", but I might get more familiar with the rolling hitch now that you've brought it up.
John
SV Laurie Anne
jrd22 is offline
post #4 of 5 Old 08-01-2007
I think this is going to be more of a problem then you anticipate. You will need to tie the bowline while you are being dragged but worse then that you will need to tie it with one hand while the water is pulling at the bitter end of the line dragging behind you and if you arenít at the end of the line you need to pull the line up to you when you tie the knot. I donít think you want to let yourself slide down to the end of the line just so that you can tie a bowline.
But now that you are tied into a line how will you get back to the boat while being dragged? Maybe having a harness with a short line in your pocket with an ascender attached will answer both questions. You can clip on and it gives you a way to work back to the boat while holding onto whatever you gain.
All the best,
Robert Gainer
Tartan34C is offline
post #5 of 5 Old 08-01-2007
Of course, the ideal situation, especially if singlehanding, is not to fall off of the boat.
Prevention beats the snot out of learning a knot in preparation for falling off the boat.... and if the boat is moving at three knots or more, the chance of you being able to pull yourself back aboard from any distance before exhaustion or hypothermia set in is minimal.
óCpt. Mal Reynolds, Serenity (edited)
StillóDON'T READ THAT POST AGAIN.
sailingdog is offline
How to size rope ModMMax Gear & Maintenance 41 12-12-2006 12:16 AM
Prop rope cutter Philip Littman Pacific Seacraft 0 11-14-2006 01:10 PM
Replacing wire halyards with rope DRM Gear & Maintenance 2 03-21-2006 03:49 PM
Rope Selection RookieHunter Gear & Maintenance 3 11-25-2002 03:03 AM
A Different Kind of Cross-Training Dan Dickison Racing Articles 0 10-25-2000 08:00 PM
