Open ocean, hole in the hull - Page 2 - SailNet Community
post #11 of 49 Old 07-18-2007
Glad to help...even if you do have a motor barge.
Originally Posted by TrueBlue
You mean those toilet flange wax rings? I had never thought of that - great idea.
TB... btw, regarding the echoes... they make something that is called a collision mat, which is already assembled with the lines, and one side is flocked or coated to help it seal against the hull better....but not real useful unless you've practiced deploying it.
sailingdog is offline
post #12 of 49 Old 07-18-2007
Seńor Member
TrueBlue's Avatar
A motor it does have (not unlike most salboats), along with two masts and three sails. But a "barge"?
This from Websters (1918):
Barge (?), n. [OF. barge, F. berge, fr. LL. barca, for barica (not found), prob. fr. L. baris an Egyptian rowboat, fr. Gr. , prob. fr. Egyptian: cf. Coptic bari a boat. Cf. Bark a vessel.]
1. A pleasure boat; a vessel or boat of state, elegantly furnished and decorated.
2. A large, roomy boat for the conveyance of passengers or goods; as, a ship's barge; a charcoal barge.
3. A large boat used by flag officers.
4. A double-decked passenger or freight vessel, towed by a steamboat.
5. A large omnibus used for excursions.
I'll accept definitions 1. & 3.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #13 of 49 Old 07-18-2007
Boasun's Avatar
Collision mats; Isn't this what they call pancakes?? LOL.
The Echos only mean that we are on the same page and are in agreement.
But a collison mat is a good thing to carry... Because if you have it, you will never need it. And if you don't? Then Oopsie, swim time.
Boasun is offline
post #14 of 49 Old 07-18-2007
Admirals fav target
We keep a tarp on board. It has many uses as shade or as extra cover when it rains. Also great when at anchor during the winter and we need a wind break on one side of the bimini. Seems to me this would work a lot better than a sail to cover a hole. Once the ingress of water is stopped the break out the epoxy and get busy.
NCountry is offline
post #15 of 49 Old 07-18-2007
TB— I only meant barge with the utmost respect for the s/v TrueBlue... Definition 2 isn't bad, but the examples they use aren't appealing.
post #16 of 49 Old 07-18-2007
moderate?
camaraderie's Avatar
I find little to disagree with above except for procedures that might be appropriate to one boat or another. I would upon determining that a significant amount of water was entering the boat:
1. Have my spouse call a Pan-Pan on the boat giving our position and situation AND preparing the light up the Epirb and gathering up the ditch bag in preparation for abandoning ship. Making sure life vests are handy.
2. I would start both my engine and generator knowing that I may need them and that batteries could be compromised early. Generator would be used to run my hi speed AC portable pump and engine would be used to keep batteries charged and POSSIBLY to evacuate water through engine water intake hose.
3. Assuming I felt the holing was controllable I would stop the boat to remove additional pressure and stuff whatever I could in to slow down the water ingress.
4. Then I would dive overboard on a tether. with some of this stuff for a temporary repair.
Syntho-Glass Fiberglass Repair Kit
If the hole were too big...the next attempt would be fast cure 5200 smeared on a plywood board and mounted outside the hull and held in place with a sail as noted above until I could get screws into the board and the hull.
Cancel pan-pan or yell mayday based on results!
camaraderie is offline
post #17 of 49 Old 07-18-2007
One other thing for the monohull sailors... depending on the location of the hulll changing tacks to raise the damaged area and reduce the amount of water getting in.
The Pan Pan call is a good idea though... let's people get an idea that you might need help... even if you don't end up needing it. However, I wouldn't light off the EPIRB until I determined whether the leak was something that could be dealt with or not.
post #18 of 49 Old 07-19-2007 Thread Starter
Thank you all for the great responses. I actually learned even more from this thread than I thought I was going to. I had never heard of putting a sail under the boat and fastening it to the deck to slow the flow of water, that's a fantastic idea assuming it would work. There were other ideas too that I will keep in my head. You all rock!
wind_magic is offline
post #19 of 49 Old 08-07-2007
Brussels Seadog
React quickly. A one-inch hole 3 feet below the waterline will allow up to 70 gallons a minute to enter your boat. Another stopping method, depending on where the hole is located, is to place a towel around the hole and wedge an upturned bucket tightly over the hole using the towel as a seal. You can try and hold the bucket in place using e.g. a broom handle wedged between the bottom of the uptured bucket and the cabin roof. It must be very tight to be effective.
If using the engine water intake to pump out as suggested by Franklanger, don't forget to put a filter over the intake - there'll be a lot of crap floating around which could be injested and block the impellor. A pair of clean socks, turned inside out together as they would be when you packed your seabag, will fit over most intakes and stay in place nicely. Plus remember that the higher the engine rpm, the faster it will pump, but don't over-rev the engine.
johngmolony is offline
post #20 of 49 Old 08-07-2007
Hi from zephyrflow
I am from "tire Town". One of you retired tire engineers invent an inflatable injectable ribbed occulsive balloute device to seal the hole. Oh Yeah, for under a hundred bucks.
zephyrflow is offline
Spring Hull Cleaning Tom Wood Gear and Maintenance Articles 0 04-05-2004 08:00 PM
hull construction cgha33 Boat Review and Purchase Forum 4 05-23-2003 07:11 PM
Building an Ocean Racer Mark Matthews Racing Articles 0 03-21-2001 07:00 PM
Southern Ocean Weather for The Race Bill Biewenga Racing Articles 0 01-28-2001 07:00 PM
Hull Speed Demystified Steve Colgate Buying a Boat Articles 0 06-10-2000 08:00 PM
