How much room...? - Page 3 - SailNet Community
post #21 of 33 Old 11-02-2007
What Ajari says makes a lot of sense. IIRC, water rights will often expire if they are not exercised... that's why you see a lot of derelict groups of pilings in Boston Harbor. The pilings represent someone's right to use that water space and if they were removed without being replaced with something new immediately, the right to use that water space would expire.
sailingdog is offline
post #22 of 33 Old 11-02-2007
Aquaholic
AjariBonten's Avatar
Hey, SD. This is a bit off topic.......
I've been around the net along time, but there is an acronym being used here I've never seen before: IIRC
What does that mean?
Thanks, Fred
I got an Old Fat Boat
She's Slow But Handsome
Hard In The Chine, but Soft In The Transom
I Love Her Well, And She Must Love Me
But I think It's Only For My Money
..... Gordon Bok
AjariBonten is offline
post #23 of 33 Old 11-02-2007
If I Recall Correctly.
post #24 of 33 Old 11-02-2007
Aquaholic
Thanks, SD....... That explains a lot.
Fred
..... Gordon Bok
post #25 of 33 Old 11-02-2007
Courtney the Dancer
jrd22's Avatar
Frank- from what you descibe I would say they were trolling, fishing lines coming off the poles, and he did not want you scaring any salmon away from his lines. 500' seems reasonable to me, but if he felt you were a threat to his lines it is pretty easy to move, as you did. In our area the biggest problem is gill netters that usually fish at night. The cork line is at least a 1/4 mi. long with only a dim white light at the end. Sometimes they will shine a light at you, sometimes not. Very easy to get into a maze of several strings set in a narrow channel. You did the correct thing. John
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #26 of 33 Old 11-03-2007
It does sound like a troller at work... and it is odd that he got excited about a 500 foot clearance.
Anyway in the end, no harm done. I imagine another fisher might not have been so concerned.. We've had trollers pass us by closer than that with no apparent worries about it.
Faster is online now
post #27 of 33 Old 11-03-2007
500 ft in a channel a mile wide seems very reasonable to me.
Rockter is offline
post #28 of 33 Old 11-03-2007 Thread Starter
Thanks, folks. It was helpful to get your opinions, so I'll know for next time.
Frank.
FrankLanger is offline
post #29 of 33 Old 11-26-2007
Rules of the road
Rule 18, Responsibilities Between Vessels
A sailing vessel underway shall keep out of the way of
(iii) a vessel engaged in fishing
so as not to create risk of collision
MMACADET is offline
post #30 of 33 Old 11-26-2007
You're under the assumption that said vessel in the OP was actually fishing...but if the vessel was fishing and didn't have the proper dayshape up...it technically ain't considered to be fishing. IIRC, the vessel is required to have the dayshape up to get right of way as a "vessel engaged in fishing". Without the dayshape and nets out...it is just a powerboat.
Center Cockpit Engine Room Ventilation Concordia Gear & Maintenance 10 12-21-2006 04:35 PM
In Search of Sea Room Micca Hutchins Seamanship Articles 0 03-26-2002 07:00 PM
Created a Sailing Room verticalmoves General Discussion (sailing related) 0 02-23-2001 07:02 PM
Protest Room Primer Dan Dickison Racing Articles 0 02-14-2001 07:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
