Emergency Anchor Setup - SailNet Community
post #1 of 4 Old 04-10-2002 Thread Starter
I sail a small boat, 21'', and came up with a way to get an anchor out off the bow without going forward. I ran a line (actually a double line loop) from the bow cleat through the bow chock and back along the starboard side and tied it to a stanchion base. All I have to do is bring up the anchor, untie the line from the stanchion, tie the anchor line on, and put it over the side.
Fran49829 is offline
post #2 of 4 Old 04-10-2002
paulk's Avatar
From your description, it sounds like you''ve only got 21 feet of scope if it is cleated at the bow at the outset. Do you go forward once the anchor is over to release more?
paulk is offline
post #3 of 4 Old 04-10-2002 Thread Starter
I have line tied to the anchor at whatever length I want (usually 60 feet for shallow water) and then tie this line to the line running back from the bow which would give me about 75 feet or so of line total. The idea is to have part of the anchor line already run to the cockpkit so I don''t have to go forward. I think this approach would also work with a sea anchor. I only used this line once last year.
post #4 of 4 Old 04-18-2002
This is the exactly the setup that the sea anchor manufacturer describes. I suppose if you need to lie to a sea anchor, you sure don''t need to be going forward.
EscapeArtist is offline
I need help with Emergency Fiberglass Repair lowryjim Gear & Maintenance 6 10-21-2009 08:51 AM
Find your emergency tiller EscapeArtist Seamanship & Navigation 20 05-24-2007 01:55 PM
Emergency Locator Transmitters markcash General Discussion (sailing related) 0 03-19-2005 09:29 AM
Emergency Fiberglass Repair lowryjim General Discussion (sailing related) 0 10-30-2004 10:23 AM
Emergency steering hole in rodder for rope? slipacre Gear & Maintenance 6 07-11-2004 03:55 PM
