Knot Suggestion Needed - SailNet Community
post #1 of 17 Old 11-17-2007 Thread Starter
We're getting ready to tarp the boat for winter. Bought a bag of Griff-Clips and a bunch of bungee cords. As luck would have it, the eyelets on the Griff-Clips are too small for the hooks on the bungee cords. So I was thinkin' of making some loops/rings out of small rope. Question is: What knot to use? Ideally it shouldn't take up much rope, but it needs to remain secure under varying, or no, load.
Suggestions?
Btw: Fooling with a double fisherman's knot, I accidentally came up with a new one. I wonder what it is? Seems secure. If I can't find it, I'll post a picture of what I've got, and maybe somebody else can identify it.
Jim
SEMIJim is offline
post #2 of 17 Old 11-17-2007
WTH is a Griff Clip???
sailingdog is offline
post #3 of 17 Old 11-17-2007
Seńor Member
TrueBlue's Avatar
The above graphic shows what appears to be a slip-knot, or better yet, a running bowline:
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #4 of 17 Old 11-17-2007
Living & Cruising on Dana
Can't be a running bowline, as both ends of the rope always face/run in the same direction. Anyway Y running a - normal 1 should do fine.
And still not sure what a Griff Clip is.
Your pleasure is my business !!!
________________________
Robby Barlow is offline
post #5 of 17 Old 11-17-2007
Thanks TB... I've seen the clips before...didn't realize they had a specific name.
post #6 of 17 Old 11-17-2007
I only know 4 knots. I'd use a bowline. It's the best, for me.
Rockter is offline
post #7 of 17 Old 11-17-2007 Thread Starter
I must've explained inadequately. I want just a loop. The idea is to create a loop that passes through the eyelet in the Griff-Clip to which the bungee can be hooked.
Surprised you didn't know what a Griff-Clip was, SD. They've been mentioned a couple times, recently, in Gear & Maintenance.
Btw: My unknown knot turned out to be a strangle knot or strangle snare. Funny that I stumbled over it entirely by accident .
Jim
SEMIJim is offline
post #8 of 17 Old 11-17-2007
Make a loop with a blood knot to join the two ends.
All the best,
Robert Gainer
Or a Double Fisherman's Bend.
Study the history of naval architecture and move forward knowing what didn’t work before.
Don’t waste time making the same old mistakes but instead make new ones and to insure your place in history be sure the mistakes are big ones.
Never design a mast that is weaker then the boat
Never design a boat that is weaker then the mast
Never listen to someone describe why your project will not work unless they can show you the broken pieces of their own version.
Tartan34C is offline
post #9 of 17 Old 11-17-2007
Not So Senior Member
Sapperwhite's Avatar
Try taking a little piece of line and pass it trough the clip, then tie a square knot with the two ends. To finish it, tie an overhand knot with each of the tails so it can't come undone. You should now have a loop big enough to work with. It doesn't have to be pretty, just functional.
If you don't like that, put one end through the eyelet on the clip, then tie a stopper knot so it can't come back through. Then tie a bowline with the free end and use that for the loop. You should tie an overhand knot with the tail in the bowline so it can't come undone during some winter storm and you lose the tarp.
You could even tie a small bowline trough the clip eyelet, and another on the other end of the line for the bungee hook.
There are a thousand ways to go about this, just use simple knots that you already know.
Dictated, but not read.
Sapperwhite is offline
post #10 of 17 Old 11-17-2007
A blood knot would work, but I'd use a Fisherman's Knot, which is basically an overhand knot tied around the standing part of each end. It uses less line than a blood knot and takes up less space.
Once the two knots are jammed up against each other, this knot is very unlikely to come loose. The higher the load, the better it generally holds.
Seven Knots You Can't Live Without Sue & Larry Learning to Sail Articles 0 11-14-1998 07:00 PM
Seven Knots You Can't Live Without Sue & Larry Seamanship Articles 0 11-14-1998 07:00 PM
