How should I tow a dinghy? - Page 7 - SailNet Community
 6Likes
post #61 of 95 Old 03-15-2010
Geekaholics Anadromous
catamariner's Avatar
On deck for longer passages, definitely. Weather can come up and you do not want to be dealing with the dinghy in a blow/waves. Agree about the likelihood of lines parting at some point (my husband managed to catch our dink on its way out of Boqueron harbor, but he's a really fast swimmer!), and about dink drag slowing the passage down - and another cool feature of on-deck is that even when it's raining you can keep the hatch open for ventilation if you have an inverted dink over it! Our Next Boat has davits, and it's not like we are going to not use them, since they are there already, but we were fine without them on the previous boat.
catamariner is offline
post #62 of 95 Old 03-24-2010
damies's Avatar
My outboard is to the starboard of my main hull, so I usually tow the inflatable off the port ama, never had a problem with it going anywhere near the prop
If the wind is likely to get over 8knots I stow it on the Port side between the ama and main hull.
The biggest problem with towing any dingy I have tried, the wake from the dingy is so much that I have to worry about no wash zones, at 6 knots the wash from the inflatable is about 10 times that from my boat, and it gets worse from there.
Dave.
Dave.
1972 Piver Trimaran 7.60m moored near Victoria Point QLD Australia.
My Daughter (Above) Described the bosuns chair as a big swing and said it was fun
damies is offline
post #63 of 95 Old 04-06-2010
snake charmer, cat herder
zeehag's Avatar
as far as towing dinks is concerned---towing in seas has made salvors very very happy to have obtained their dink for FREE!!!!! and if ye leave the engine on , is a great help to them, as they donot have to go about purchasing one---lol....there are many folks who have felt that towing was necessary, they are out seeking new dinks as we speak...goood luck and fair winds.....i tow mine by deflating it and stowing on board--the engine goes before the mast quite nicely and i donot have to worry about losing mine to salvors....smooth sailing.....
zeehag is offline
post #64 of 95 Old 05-22-2010
seeker of wonder
SoulVoyage's Avatar
Depending on conditions, I either "stow it or tow it". But when I DO tow my dinghy (a small hypalon inflatable), I actually bring it VERY close to the stern and tow it backwards, so that only the bow of the dink is in the water. The two pontoon ends brought nearly against the hull. I've never had a problem with abrasion by doing this.
There is an added benefit of doing it this way: When I get to whatever anchorage, or back to the slip, I simply take the mizzen halyard and clip it to the bow bridle and lift the bow of the dinghy right out of the water. As the pontoon ends are already OUT of the water and secured, this keeps the WHOLE dinghy out of the water!!...and out of reach form algae and barnacles. To drop the dinghy in the water, it is a simple task to let go the mizzen halyard. If you don't a mizzen, the main halyard should work just as well to get the bow out of the water while at anchor or dock.
This system works great for me, and doesn't cost a dime and keeps the dink's bottom MUCH cleaner, as the whole thing is out of the water while sitting, yet still immediately ready to go.
"...and a star to steer her by."
SoulVoyage is offline
post #65 of 95 Old 05-26-2010
joni duncan
snb25 joni
wow that alot of ideas i just use a 6 foot floating line i also have a 6 foot hepalon dingy
snb25 is offline
post #66 of 95 Old 09-06-2010
Hey, SoulVoyage, i've thought about this, but haven't come up with a way to do it yet...
rather than re-invent the wheel, can you give me (us) some advice and/or pix on how you did it?
i have a 1972 Morgan 30/2, Yanmar inboard (so no O/B bracket on the stern), with an 8 foot Caribe RIB and a 15 HP Yam 2 stroke O/B
thanx!
(i tried to PM you, but apparently i have to have 5 posts before i can PM anybody. i thought it was easier to do this than to make up 5 "junk" posts! )
OKCUBye is offline
post #67 of 95 Old 09-07-2010
5hortBu5's Avatar
Behind a Miata?
5hortBu5 is offline
post #68 of 95 Old 09-18-2010
Capt Ron
southwindphoto's Avatar
Originally Posted by denby View Post
I lift the bow of the dinghy up to the stern rail and tie dinghy handle to rail. Then run lines from each carrying rope on sides of dinghy to stern cleat on each side. Only the aft end of dinghy touches the water.
I like the idea.. how does it work in a fallowing sea.. Any problems
southwindphoto is offline
post #69 of 95 Old 09-19-2010
I used to tow way back (30-40 feet), but lately have been towing close, with the dinghy almost touching the stern. Seems to generate less drag, but i'm not sure.
How far back does everybody else tow? (i keep my o/b on the dinghy)
OKCUBye is offline
post #70 of 95 Old 09-19-2010
I used to tow way back (30-40 feet), but lately have been towing close, with the dinghy almost touching the stern. Seems to generate less drag, but i'm not sure....
OKCUBye is offline
Choosing a Dinghy Sue & Larry Gear and Maintenance Articles 0 10-11-2004 08:00 PM
How to Tow a Dinghy Dan Dickison Gear and Maintenance Articles 0 04-15-2002 08:00 PM
