Problem leaving the dock...... - SailNet Community
post #1 of 25 Old 07-01-2008 Thread Starter
Unhappy Problem leaving the dock......
hi
the attached diagram explains my problem.
when leaving the marina, due to the prevailing wind and the propwalk, I find myself being pushed out of the marina, stern first. NOT GOOD!
I am the black boat in the diagram.
I am looking for some advice on how to counteract these forces, so I just back out and head out bow first.
some have suggested backing into the slip, however all the other boats are facing bow in, and I would like to know how to do it!
thanks
jc
alameda007 is offline
post #2 of 25 Old 07-02-2008
It would be helpful to know what size/design your boat is so we have an idea how it might handle under various conditions. Your situation is a common one as far as marina arrangements go...
Faster is offline
post #3 of 25 Old 07-02-2008
Boasun's Avatar
One method is to put a line over to the up wind float from about a little aft of your amidships and swing out on that line as you leave the slip. and when you are lined up for moving out of the main slip, slip the line clear of that float. the line should go from you boat and back again so you can retrive it when you slip it.
This will take practice and adjustment of where you need to place that line on your boat.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Boasun is offline
post #4 of 25 Old 07-02-2008 Thread Starter
type of boat...
it is an ericson 27, spade rudder
post #5 of 25 Old 07-02-2008
Courtney the Dancer
jrd22's Avatar
I agree with Boasun- if your boat walks to stb in reverse and you are fighting wind you will need to rig a line to help swing her around. We had the same problem and that's what we did, it's easy after the first couple of times.
John
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #6 of 25 Old 07-02-2008
artbyjody's Avatar
Or the easiest is to back in - which is how I solve the problem...just because everyone else goes bow in doesn't mean stern in is bad. Just usually means they do not know how to steer it in reverse... I personally, actually find its easier backing in, and a heck of alot easier getting out...
-- Jody
S/V "
1983, Barberis Show 38! or
artbyjody is offline
post #7 of 25 Old 07-02-2008
Second the backing in idea... the prevailing winds will help push your bow to the correct side of your slip - but you'll need to do it with some speed to start with so that you have good steerage and control. Practice alongside a drifting log or open float somewhere first!
Faster is offline
post #8 of 25 Old 07-02-2008
Sailor
Plumper's Avatar
I find it odd that the stern doesn't seek the wind as you back out. 99 out of 100 boats seek the wind going astern. In any event, the line to the dock is the seamanlike way to do it.
There is a tide in the affairs of men,
Which, taken at the flood, leads on to fortune;
Omitted, all the voyage of their life
Is bound in shallows and in miseries.
Shakespeare, Julius Caesar IV, iii, 217
Plumper is offline
post #9 of 25 Old 07-02-2008
Owner, Green Bay Packers
The DVD here will show you how to rig that line for this situation and many others. I'm not much impressed with most teaching videos out there, but this one is very good. Well worth the money. Sale page for Captain Jack Klang
Wm. F. Buckley, Jr.
sailaway21 is offline
post #10 of 25 Old 07-02-2008
Send a message via AIM to NauticalFishwife
I keep Jack Klangs book under my navigation table. And referred to it just recently when the wind was blowing us onto a T dock, we were wedged between two boats and needed to leave. We were the transients.
Have your home slip all set up for your return. When backing in if you have your spring line on the outer piling as soon as you get that set on your mid ship cleat your boats stern will go to that finger pier. If you have a middle piling secure your stern lines there when you leave and as you back in you can reach those and have control of your stern-side to side motion-the spring line has stopped any reverse motion and PRESTO-you're in your slip. I have my spring lines color coded and as silly as it sounds when I take people out who do not sail I put a piece of colored tape on the stanchions the spring line goes between. And I have a spliced loop on the spring line so all they have to do is drop it over the cleat. Send me a PM if you want my suggestion on how to secure your stern lines to make them easy to reach when you return. Good luck! Oh...and if you don't back your boat in at our marina...people tease you without mercy! I've often thought it might be nice to have davits just so I'd have an excuse to bow in!
Also take a look at how those around you do. The ones without lots of dings.
"The God's do not subtract from man's
(or woman's) allotted time the hours spent in sailing."
Martha
Calypso-Dickerson 37
NauticalFishwife is offline
Yanmar Starter dave6330 Gear & Maintenance 21 12-18-2015 06:52 PM
3GM: Engaging the starter idiosycrasies welshwind Gear & Maintenance 15 09-04-2008 07:08 PM
1981 Honda 9.9, 4 stroke o/b, Idle problem randj65 Gear & Maintenance 4 06-19-2002 11:59 AM
Engine Oil Pressure Problem msamelso Gear & Maintenance 2 02-20-2001 07:25 PM
