Navigation tools - Page 2 - SailNet Community
post #11 of 21 Old 08-13-2008
Valiente's Avatar
Protractor of the type shown, and I also use dividers to measure distance and a three-armed protractor
It is handy in conjunction with a chart and a horizontally held sextant or hand-held compass in determining "distance off" in coastal pilotage. A hand-held compass is usually accurate enough, but if the coast is obscured by mist/fog, and you can only make out, say, a tower miles off the bow and a radio mast miles off the stern, this and knowing your true heading can give you a surprisingly accurate fix.
Valiente is offline
post #12 of 21 Old 08-13-2008
moderate?
camaraderie's Avatar
I used the "cheat tool" exclusively for our adventures. Nothing else I've tried can give you anything you want in the cockpit in 10 seconds or less. An incredible tool and SO much easier to use than the damn parallel rules.
camaraderie is offline
post #13 of 21 Old 08-13-2008
the pointy end is the bow
erps's Avatar
Weems & Plath Chartkit Plotter
Here's the link the the portable chart board
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #14 of 21 Old 08-14-2008
poopdeckpappy's Avatar
Here's another vote for the Cheat tool
WP has a basic kit the has the Protactor plotter, parallel rule, dividers and even a pencil.............under 50 bucks
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #15 of 21 Old 08-20-2008
Sailor
Plumper's Avatar
Cheat tool! For sure.
There is a tide in the affairs of men,
Which, taken at the flood, leads on to fortune;
Omitted, all the voyage of their life
Is bound in shallows and in miseries.
Shakespeare, Julius Caesar IV, iii, 217
Plumper is offline
post #16 of 21 Old 08-20-2008
Unless you're familiar with how to use triangles, I'd recommend the beginning navigator avoid them...they're a PITA... the cheat tool is a much better choice for the N00b...since it is just much more intuitive than either triangles or the traditional parallel rules.
Also, the GPS Plotter parallel rules are better than the traditional ones, since they don't crab as you use them.
Here is an animated image of how to use the GPS Plotter:
sailingdog is offline
post #17 of 21 Old 08-30-2008
Closet Powerboater
MedSailor's Avatar
I have a rolly ruler thingy and I don't like it very much, the wheels often stick or catch and it doesn't stay parallel. Also it can't go up or down the chart, only across it, so unless it's as big as your chart odds are it won't work well as you are above or below the nearest compass rose. I plan on getting parallel dividers and some more cheat toys soon.
If you insist on the rolly ruler I'll pass on a tip from someone much saltier than I. He had 1ft long broom handle piece (dowl). It rolls beautifully across the chart and since it doesn't have silly little wheels to skid or jam it always stays parallel. Floats too which is important for any boat tool.... The downside is that the instructor will assume you know exactly what you're doing and treat you as such.
MedSailor is offline
post #18 of 21 Old 08-30-2008
Arf!
pegasus1457's Avatar
Best dividers around ..
Originally Posted by lbdavis View Post
Personally, I really like the protractor:
I would suggest a good set of dividers, FWIW.
Agreed -- By chance I bought an inexpensive divider at WM that I really love. It has a little wheel which allows controlled fine adjustments but which can also be changed in coarse increments, overriding the wheel. It sells for less than $20 and beats any of the traditional brass dividers..
Fluctuat nec mergitur
pegasus1457 is offline
post #19 of 21 Old 08-30-2008
Arf!
another kind of protractor
I gave up on the rolling rulers when I discovered that the little aluminum wheels corrode when exposed to salt air. I had to toss mine.
I learned to use a different kind of rule while sailing in France. It is called the regle de Cras (Admiral Cras' rule). It is a protractor-based rule with no moving parts. It works very well and doesn't require a large nav table.
Last edited by pegasus1457; 08-30-2008 at 11:04 PM. Reason: changed parallel rule to rolling ruler
post #20 of 21 Old 08-30-2008
ancient mariner
captbillc's Avatar
"Cheat Tool"
;353253]Personally, I really like the protractor:
Some may call it a "cheat tool", but this thing is great. I find it amazing what can be done with this.
I would suggest a good set of dividers, FWIW.[/QUOTE]
lbdavis ----- i use a similar tool. it"s a Dockley's and has a 20" rule on the top and rotating compass rose in the middle with a round lock nut. on each side of the rose is a line which indicates the course. you put the compass rose on a meridian & read the course on the line,or put the ruler on the course you want & 0 degrees on a meridian and read your true course at the line on either side, depending on which way you are going. this is the easiest ploting tool i have used.. i have a weems & plath divider with the hand wheel also. it has removable points so you can put min a lead & use it as a compass. captbillc
captbillc is offline
Working With the Stars—Celestial Navigation Jim Sexton Seamanship Articles 0 05-06-2003 09:00 PM
Working With the Stars—Celestial Navigation Jim Sexton Her Sailnet Articles 0 05-06-2003 09:00 PM
Navigation Basics Jim Sexton Learning to Sail Articles 0 01-04-2002 08:00 PM
Navigation Basics Jim Sexton Seamanship Articles 0 01-04-2002 08:00 PM
Navigation Basics Jim Sexton Her Sailnet Articles 0 01-04-2002 08:00 PM
