rope to wire halyard knot - Page 2 - SailNet Community
post #11 of 44 Old 09-12-2008
Rx-
Most are too slippery for knots. However, that article is over four years old, and some of the materials in use today were not around four years ago, or at least not in common usage as they are today.
sailingdog is offline
post #12 of 44 Old 09-12-2008
johnshasteen's Avatar
I replaced my wire-rope halyards with Sta-Set X, no less tension than the old wire-rope.
s/v Paloma, Bristol 29.9, #141
Slipped in Bahia Marina, easy access to Corpus Christi Bay and the Gulf of Mexico.
johnshasteen is offline
post #13 of 44 Old 09-12-2008
StaSetX
Originally Posted by kgs113 View Post
With my main and jib halyards the wire part ends with a nicopress loop. I secure the line with a buntline hitch. Going to Stay Set X after I step the mast and see what I have for sheaves.
Pay particular attention to the stiffness of StaSetX. I've gotten to the point where I won't use it for any application because it is so ornery.
To replace almost any halyard, I would make a composite halyard using Dyneema or Vectran for the shackle end covered with a polyester cover at the hauling end. Analogous to wire with rope tail.
Cheers,
MikeR
GoslingNY is offline
post #14 of 44 Old 09-12-2008
Boasun's Avatar
If you change from wire to line for your halyard, you have to change out the sheaves at the top of the mast.
1. With a wire/rope halyard the sheave has a grove in the base of the sheave for the with with a wider one for the rope.
2. With an all line halyard you will want the appropriately sized grove to fit that halyard.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Boasun is offline
post #15 of 44 Old 09-13-2008
Interesting, and yes, if you change over to all cordage the sheaves should be changed. However, I've found that the smaller diameter 12 strand dyneema or vectran (ie 3/16" diameter for boats of our size), lies snugly in the wire groove of the combo sheaves usually found on our boats. You should, no matter what you do, carefully look at the sheaves and clean them up with a file and emery paper. Decades of wire use will usually leave lots of wear which will quickly abrade any cordage you replace the wire with.
Cheers,
MikeR
post #16 of 44 Old 09-13-2008 Thread Starter
Thanx everyone. Having read most of that info before I posted my question I should have asked what, other than knots being weak points, the problem would be having external halyards with no turning blocks secured to the wire with a knot. The knot will not have to pass through any sheaves either.
I'm day sailing on a small lake.
gtunison is offline
post #17 of 44 Old 09-13-2008
Look into
My Triton and Ariel both have rope/wire halyards, the triton is a wire>rope splice, but the ariel has a small double link between them with a thimbled eye splice in both wire and rope. Link is a single peice, but has a double link chain look to it, made of bronze, and is a lightning bolt like Z shape in profile. I'll try to remeber to get a pic while the mast is down.
Haven't sailed her yet, but finaly got the mast moved around and had a chance to inspect it, PO claims everything is original, (spent MANY years in dry storage) so it may be an off-the-shelf item somewhere. was raining heavily so I didn't play with it to see why the Z shape was required or even if it was, from a quick look it may just be to keep the wire off the mast.
When I got my triton, I looked into replacing the halyard with stayset or some such, but the required changes were more than I wanted to mess with, so I just had the splice done.
Making the conversion, means that future changes can me done with greater ease, but realy only a concern if you plan to keep the boat for the lifetime of a new halyard.
Ken.
merc2dogs is offline
post #18 of 44 Old 09-13-2008
kgs113's Avatar
I have already talked to a machinest friend in regard to new sheaves when I step the mast this fall. Gotta take a closer look to figure out what I'm going to do. In the meantime, my buntline hitch seems to be working well. Thanks for the advice.
kgs113 is offline
post #19 of 44 Old 09-23-2009
I need to learn that splice
I have a halyard running up to a pulley that is only large enough to accommodate a thin wire rope. Where can I learn how to do that splice?
roblusignan is offline
post #20 of 44 Old 09-24-2009
The Complete Rigger's Apprentice by Brion Toss explains a lot of these splicing techniques. Checked it out of the library to learn how to do double braid eye splice - but used some You Tube videos as well.
JP
Crapaud is offline
Rope mats GoodOldBoat Good Old Boat 24 05-23-2015 05:46 PM
Halyard Changing wire to rope? saurav16 Gear & Maintenance 9 05-10-2008 02:18 PM
Offshore Log: Check Your Lifelines, Save Your Life PracticalSailor Gear and Maintenance Articles 3 04-26-2007 12:23 PM
Keeping Wiring Woes at Bay Chris Brignoli Gear and Maintenance Articles 0 01-26-2004 07:00 PM
Electrical Work Rules Don Casey Gear and Maintenance Articles 0 07-16-2000 08:00 PM
