Lee helm - Page 2 - SailNet Community
post #11 of 24 Old 10-21-2008
Thanks Courtney.
Dog- He says he HAS a riding sail.
Idiens- He is complaining about LEE helm, not weather helm.
Jim / DrB - You should both invest in a better topping lift.
Solla- Dog is right. without telling us what boat you have and what sails you're using, about all you're going to get is pretty much just going to be guess work.
hunter Legend 37 Semper Paratus
Formerly - Tartan 34C Yawl
T34C is offline
post #12 of 24 Old 10-21-2008
Why do I need to "invest in a better topping lift?" (Setting aside for the moment you don't know what our boat currently has for a topping lift.)
Jim
SEMIJim is offline
post #13 of 24 Old 10-21-2008
Thanks Courtney.
Jim
Sorry, just went back and reread what you wrote and shouldn't have included you in that.
T34C is offline
post #14 of 24 Old 10-21-2008
DrB
Topping Lift
Okay (T34C), if you didn't want to include SEMIJim, I guess that the comment was directed at me, so how is a topping lift, which keeps the boom from dropping, supposed to help keep it from not bounching up or swinging back and forth when there is little tension on the main sheet. The OP said there was little wind, so in my experience when I have tried that set-up, the boom "bounces" as the boat rocks or bobs from wake or waves unless there is enough air pressure on the sail to keep it filled.
DrB
DrB is offline
post #15 of 24 Old 10-21-2008
Solla Sollew
Yes, the boat is a Bavaria and yes, on a stbd tack the wheel needs to be at 3 o'clock (that's actually optimistic) to point up into the 'wind'.
Originally Posted by JohnRPollard View Post
Eric,
I understand the keel configuration (Bavaria uses something similar). But I'm having trouble reconciling your description of "lee helm" with your statement that the helm is at "3 o'clock".
Are you saying that, on a starboard tack, you must turn the wheel about 1/4 turn to starboard? And, on a port tack, you must turn the wheel 1/4 turn to port?
Are or you saying the opposite, i.e. that on port tack you must turn the wheel 1/4 turn to starboard, and vice versa?
SollaSollewSails is offline
post #16 of 24 Old 10-21-2008
Moderator
JohnRPollard's Avatar
Okay, just wanted to confirm that we are talking about lee helm.
I won't re-hash the good advice offered above to combat lee helm. Idiens mentioned adjusting mast rake forward to combat weather helm, and obviously the opposite is true. Before trying the advice previously offered, I would confirm that you have the proper mast rake dialed in. Once you confirm that the rig is tuned to spec, then you can fiddle with the other suggestions.
P.S. SailNet has a pretty strict policy against using multiple sign-on names:
http://www.sailnet.com/forums/genera...e-signons.html
Suggest you contact one of the Moderators and ask them to merge your account.
JohnRPollard is offline
post #17 of 24 Old 10-21-2008
Solla Sollew
Sailing at Anchor
The link to the Don Jordon article is very instructive with regards to the issue of sailing around at anchor. The Bavaria mast is rather far forward and may indeed act as the feathers on a arrow (as he notes) leading to instability when moored from the bow. I think the idea of a riding sail is essentially to create bigger feathers at the stern. Obviously mine were not quite big enough. Rigging the anchor from the stern is a nice idea though it does not seem very practical. One thought is to keep everything as it is but instead to snub from a stern cleat. Here's the scenario:
  • Say depth, etc dictate 100 feet of chain. Anchor with 60 then attach a 40 foot snubbing line (length of the boat plus 6 feet extra).
  • Carry the bitter end of the snubbing line to a stern cleat (extra credit for a bridle of some sort) and attach.
  • The boat is still bow to the wind since no additional chain has been let out. The snubbing line is 'flaccid'.
  • Now, let out the remaining 40 feet of chain.
  • Gradually the snubber will take the load and harden up just as it normally would except this time it's attachment point is at the stern.
  • End result, stern-to anchoring
I'm just thinking out load here so please limit sarcastic assessments about what an idiot I am.
As for sailing at anchor: Either get a riding sail made up or anchor by the stern. Don Jordan has a very good argument for anchoring by the stern—but many boats don't have the gear necessary to do it.
Lee helm, especially very consistent lee helm as you have on your boat, is often caused by a problem in the rigging—if it isn't a problem with the original design to begin with. It would help if you said WHAT FREAKING BOAT YOU HAVE. Some boats have known issues with severe lee/weather helm and many have known solutions. It could be something as simple as adjusting the mast rake a bit.
post #18 of 24 Old 10-21-2008
Solla-
You'd have to let out an extra 75' of chain or so—starting with the 60' where the snubbing line is attached. Since you need to let out enough chain to get the snubbing line attachment point 40' or so from the stern of the boat. If you only let out 40' of chain, you'll have a bridle, with one chain leg and one rope leg and the boat perpendicular to the main part of the anchor rode... that'd probably be a bad way to anchor.
sailingdog is offline
post #19 of 24 Old 10-22-2008
Solla Sollew
Getting a bigger riding sail is probably a better idea.
EG
post #20 of 24 Old 10-22-2008
So does the wheel need to be at 9 o'clock on a port tack, as well?
Jim
SEMIJim is offline
How do I correct a lee helm? samsciacca General Discussion (sailing related) 10 08-20-2007 09:28 PM
lee helm jrwright Learning to Sail 6 05-25-2004 02:58 PM
The Balance of Hull and Sails Steve Colgate Learning to Sail Articles 0 05-25-2000 09:00 PM
The Balance of Hull and Sails Steve Colgate Seamanship Articles 0 05-25-2000 09:00 PM
The Balance of Hull and Sails Steve Colgate Buying a Boat Articles 0 05-25-2000 09:00 PM
