Anchor Trip Line 101, Please - Page 2 - SailNet Community
post #11 of 49 Old 02-18-2009
AdamLein's Avatar
That sounds like it would be great for making your anchor visible, but doesn't it create problems with setting and maintaining a good set? Where do you attach the buoy line, to the crown, or the end of the shank? I guess if you use a small buoy the buoyancy would be completely overcome by the weight of the anchor and chain, but still seems a little iffy. I can see myself losing sleep, worrying about the buoy pulling the anchor out.
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #12 of 49 Old 02-18-2009
the pointy end is the bow
erps's Avatar
I suppose it depends on how big your buoy is. Ours is a cork. Its pull is neglible. After switching to a Mason Supreme anchor, I can sleep well at night after a good set on very little scope in benign conditions. The bugger is hard to break out of the mud without using the boat's momentum, so an underwater buoy wouldn't concern me. (P.S., I don't sleep on a 1 to 1 scope, but I think I could in the right conditions)
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #13 of 49 Old 02-18-2009
Originally Posted by AdamLein View Post
That sounds like it would be great for making your anchor visible, but doesn't it create problems with setting and maintaining a good set? Where do you attach the buoy line, to the crown, or the end of the shank? .
The idea (if using an "underwater" anchor buoy) is to use a very small float, to just make the line buoyant. I use a small float that is round with a hole in the middle like a donut. It is only a couple of inches long. They are used by the 100s on fishing nets in the Med so you can often find them beachcombing.
Any trip line should be attached as far forward and low down as possible, so the anchor can be pulled out backwards.
noelex77 is offline
post #14 of 49 Old 02-18-2009
hey guys...that is what I was talking about when I described using poly line. IT FLOATS!!! no need for a small bouy. It will suspend straight up to the height you set it. Put a loop in the end for attaching another line if necessary
xort is offline
post #15 of 49 Old 02-18-2009
AdamLein's Avatar
Aha, I was picturing the sort of buoy that you use to mark crab traps.
xort - the difference between poly line and the buoy is probably one of visibility. Waters in PNW are pretty murky and vis is basically zero below ten feet, especially during summer when that pesky environment thing starts growing all over the place.
One thing I would do with the little buoy -- or with the poly line -- is to somehow paint it with reflective paint or otherwise make it reflective. Even on low-vis days, reflective objects can stand out like spotlights underwater.
AdamLein is offline
post #16 of 49 Old 02-18-2009
djodenda's Avatar
Originally Posted by erps View Post
That's a good idea. I've gone down to check my anchor from time to time up here in the PNW and when it's set, it's invisible.
Um.. Ray.. The water's like really cold here. Deep, too. Do you scuba, or are you some kind of superman?
I'm totally paranoid about anchoring, but there's NO WAY I'm diving an anchor up here!
DAvid
David
1987 CS 36 Merlin "Kyrie"
djodenda is offline
post #17 of 49 Old 02-18-2009
AdamLein's Avatar
David: my guess would be he doesn't anchor in very deep water Besides, the PNW has a pretty devoted freediving community.
erps, I am curious as to whether you go through all the trouble of donning a wetsuit before you dive your anchor...
AdamLein is offline
post #18 of 49 Old 02-18-2009
erps's Avatar
DAvid
Hi David,
I do SCUBA and some free diving as well. I've checked the anchor at Hope Island once and at Roscoe Bay a couple of times. The chain disappears into the mud up to 20 feet or more from the anchor. Finding it without some sort of a buoy as suggested by Xort and Noel would be difficult.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #19 of 49 Old 02-18-2009
djodenda's Avatar
Cool.
If my anchor ever gets stuck, or I lose a crab pot, I'll be sure to call you.
David
David
djodenda is offline
post #20 of 49 Old 02-18-2009
blue collar cruiser
soulesailor's Avatar
erps, that video is seriously cool!
who is staring at the sea is already sailing a little
soulesailor is offline
Which Ocean is the bad boy?? Giulietta General Discussion (sailing related) 48 07-19-2012 04:53 PM
Getting Good Starts, Part Two Zack Leonard Racing Articles 0 01-15-2004 07:00 PM
Getting Good Starts, Part One Zack Leonard Racing Articles 0 12-18-2003 07:00 PM
Hold That Line Tom Wood Gear and Maintenance Articles 0 10-03-2002 08:00 PM
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 08:00 PM
