Right of way scenario... - Page 2 - SailNet Community
post #11 of 60 Old 05-18-2009
jackdale's Avatar
Originally Posted by bacampbe View Post
Would a hove-to boat with the skipper eating lunch count as "not under command?"
Not under command means a vessel which through some exceptional circumstance is unable to manoeuvre as required by these Rules and is therefore unable to keep out of the way of another vessel. Usually that means that the propulsion system or steering system is BROKEN DOWN.
Jack
jackdale is offline
post #12 of 60 Old 05-18-2009
Valiente's Avatar
Was Boat A displaying the required dayshape to indicate "not under command"? I would suggest "restricted maneuverability" would be in fact the correct dayshape.
My guess is no, you were not.
You were in fact sailing if you were making two knots, indicating you were in a current or your boat was not stalled out and drifting downwind. You just weren't sailing very well. I would suggest that it would be difficult for a boat sailing close-hauled at five or six knots to distinguish your "hove to" from "poor sailing, but sailing nonetheless" as two knots is pretty fast movement for "hove to". Had you displayed the appropriate dayshapes (which I know few own and fewer use, even fishermen or dredgers), there would have been less ambiguity and more a response of "I don't know what those cones and balls mean, but I do know I'll give it a wide berth...READY TO TACK..."
You were counting on another sailor to divine your intention to remain hove-to. That's not his duty. You were moving, if slowly, and were the windward boat. Therefore the onus was on you to make your intentions known to him. You could've used a signal horn, also, or a bell, but that's not generally understood these days either, although it's probably a better bet than dayshapes!
Can't sleep? Read my countdown to voyaging blog @
Valiente is offline
post #13 of 60 Old 05-18-2009
jackdale's Avatar
I do not think a hove-to vessel is RAM
The term "vessel restricted in her ability to manoeuvre" means a vessel which from the nature of her work is restricted in her ability to manoeuvre as required by these Rules and is therefore unable to keep out of the way of another vessel.
The term “vessels restricted in their ability to manoeuvre” shall include but not be limited to:
(i) a vessel engaged in laying, servicing or picking up a navigation mark, submarine cable or pipeline,
(ii) a vessel engaged in dredging, surveying or underwater operations,
(iii) a vessel engaged in replenishment or transferring persons, provisions or cargo while underway,
(iv) a vessel engaged in the launching or recovery of aircraft,
(v) a vessel engaged in mineclearance operations,
(vi) a vessel engaged in a towing operation such as severely restricts the towing vessel and her tow in their ability to deviate from their course.
I use an MOB method that involves heaving-to twice. It ensures that we can manoeuvre.
Jack
jackdale is offline
post #14 of 60 Old 05-18-2009
IMHO a boat that is "Hove to" is not sailing and may as well be at anchor,even more so if wind on starboard, and hence should be stand on vessel.
And yes, I agree-need to display the dayshapes!!
jimmytc is offline
post #15 of 60 Old 05-18-2009
Valiente's Avatar
Jack
Technically, you're correct. However, I would argue that hoisting a dayshape in this situation (boat is semi-sailing, crew is below) is better than nothing.
As my wife commented when I had her read this entire thread to make sure I was making sense, "if you pull over just onto the shoulder on the highway without putting on your four-way blinkers, how am I to predict when you are going to open your door, or whether you are still even running the engine? I have no information as to your intentions."
This is why I have full confidence in my wife's ability to take a watch and helm. She thinks this way out of the box!
Valiente is offline
post #16 of 60 Old 05-18-2009
jackdale's Avatar
In fact, hove-to is sailing.
The term "sailing vessel" means any vessel under sail provided that propelling machinery, if fitted, is not being used.
The word "underway" means that a vessel is not at anchor, or made fast to the shore, or aground.
Jack
jackdale is offline
post #17 of 60 Old 05-18-2009
AEOLUS II
WouldaShoulda's Avatar
Originally Posted by jrd22 View Post
Boat A- enjoying a nice day on the water, hove to, eating lunch. Boat B- jerk that felt it necessary to demonstrate his lack of class.
WouldaShoulda is offline
post #18 of 60 Old 05-18-2009
jackdale's Avatar
There is no day-shape for hove-to.
Hove-to is sailing. (see previous post #16)
You are also required to maintain a lookout at all times.
Jack
jackdale is offline
post #19 of 60 Old 05-18-2009
jackdale's Avatar
Check out pages 170 -171 of the following:
TinyURL.com - shorten that long URL into a tiny URL
A hove-to vessel on a port tack must keep out of the way of a vessel on a starboard tack. In this case the hove-to vessel was reefing.
Jack
jackdale is offline
post #20 of 60 Old 05-18-2009
Rule 13 Overtaking) Regardless of ANY other rule,an overtaking vessel must keep out of the way. Boat B is a ASS. Boat A was right in getting ready to makeway,risk of collision if in doubt assume collision.
ctl411 is offline
Owning a Boat is EXPENSIVE! CaptainFredGreenfield Boat Review and Purchase Forum 227 07-25-2009 07:16 PM
Scenario deniseO30 Boat Review and Purchase Forum 26 10-13-2007 11:58 AM
