Storing whisker pole vertically - SailNet Community
post #1 of 15 Old 12-05-2009 Thread Starter
L124C's Avatar
I have come up with a way to store my whisker pole vertically, and I don't see anyone else doing it. I'm wondering why.
I hook one end of the pole on the mast ring where it will be attached when used. The other end of the pole is secured to the topping lift, and lifted vertically. So, the pole and mast are parallel. Then, I only have to release the topping lift to lower the pole into place for use. The only possible drawback I can see, is that the pole might bang against the mast in big seas or heavy winds, (though it seems pretty secure in the slip). If so, I could pad it. It sure seems a lot more convenient than storing it horizontally on deck. Anyone see other problems?
L124C is offline
post #2 of 15 Old 12-05-2009
celenoglu's Avatar
I normally store it as you describe. The pole bangs to the mast but I normally wrap the spinnaker line around both the pole and the mast.
celenoglu is online now
post #3 of 15 Old 12-05-2009
paulk's Avatar
People don't store their spinnaker or whisker poles vertically on the mast because when they work loose (all by themselves, it just suddenly happens!) they drop down and (pick any two) 1/hit people who are sunning on the foredeck, causing a 4" gash that leaves bloodstains that are a real chore to clean up 2/hit the deck, causing a 2"gash and cracks that cost $1500 to fix 3/hit the hatch, requiring a new $800 hatchcover, 4/ torque and break the $300 end fitting, the $100 mast fitting, and possibly the $100 track, which will cost $750 to re-install. If you calculate how long the pole is and how much leverage that affords at the business end, you will probably stow your whisker or spinnaker pole on deck. If it is too heavy to handle, each of those pounds is adding to the leverage and/or impact of the pole. Perhaps carbon fiber would be a lighter option. Despite its cost, it may end up being cheaper than the alternatives.
paulk is offline
post #4 of 15 Old 12-05-2009
Moderator
JohnRPollard's Avatar
I frequently see spin/whisker poles stowed in this manner, except that those who do normally use some mounting hardware to secure it and free the topping lift for other purposes (see, e.g. Mast Mounted Pole Chock )
I would invest in the mounting hardware and avoid any possibility of it coming lose or banging the mast.
JohnRPollard is offline
post #5 of 15 Old 12-05-2009
Yorksailor's Avatar
Paul is right, we store two vertically and one fell...it was not damaged as my wife's head was between it and the deck.
They bang unless they are well secured but they are much easier to deploy which is important on a 55ft boat with a 70ft stick.
Phil
Yorksailor is offline
post #6 of 15 Old 12-05-2009
paulk's Avatar
Sorry to have been proved right that way. Ouch!
paulk is offline
post #7 of 15 Old 12-05-2009
Chesapeake Sailor
wwilson's Avatar
There are a number of boats that stow the pole on the mast. HR is one. The upper end is secured to a track on the mast. It comes lose only deliberately for removal. The pole has a hoist line allowing it to be lowered or raised under control to set the proper angle for spinnaker or jib (as whisker pole)
The outboard (lower) end attaches to a bail at the base of the mast when stowed. Once stowed it is fully secured. Ours has had the green water test a number of times.
Wayne
wwilson is offline
post #8 of 15 Old 12-05-2009
Ex Member
Originally Posted by wwilson View Post
There are a number of boats that stow the pole on the mast. HR is one. The upper end is secured to a track on the mast. It comes lose only deliberately for removal etc. The pole has a hoist line allowing it to be lowered or raised under control to set the proper angle for spinnaker or jib (as whisker pole)
Wayne
Same kind of setup on the Oyster I sail offshore on. Conventional-ish topping lift to the middle of the pole, but the mast end height is also controllable. When the pole goes away the mast end goes up, topping lift eased, and then the outboard end of the pole clips into a ring at the base of the mast. Haul the mast end tight, remove the topping lift (or not, depending) and you're done. Easy stuff, boat had seen way more than its share of green water, no problems
ste27 is offline
post #9 of 15 Old 12-05-2009
Since a whisker pole is much lighter/smaller than a spinn pole, if you have a track try using two rings, one near the top of the track and slip the pin end through, clip the other end into the ring at the bottom,or to an appropriate fitting lower down near the deck.
Simply pulling the pole vertical with the pole lift is not going to be very stable in any kind of action underway.
Faster is offline
post #10 of 15 Old 12-06-2009 Thread Starter
L124C's Avatar
Phil
I'm a little confused. Despite the horrific incident, you still seem to be a proponent of the vertical system. What went wrong, and do you still have the same wife?
L124C is offline
whisker pole ?????? mangomike General Discussion (sailing related) 4 10-01-2006 09:05 PM
Downwind Passagemaking Mark Matthews Seamanship Articles 0 10-01-2002 09:00 PM
Whisker Pole vs Cruising Spinnaker r2straebel Gear & Maintenance 5 01-24-2002 09:25 AM
Using a Whisker Pole Dan Dickison Racing Articles 0 09-04-2001 09:00 PM
Using A Whisker Pole Dan Dickison Learning to Sail Articles 0 04-23-2001 09:00 PM
