Rules of the Road (Quiz) - Page 3 - SailNet Community
post #21 of 463 Old 12-22-2009
1.) Meeting, Passing, Crossing
2.) A vessel of less than 20 meters or a sailing vessel shall not impede the passage of a vessel that can safely navigate only within a narrow channel or fairway.
tempest is offline
post #22 of 463 Old 12-22-2009
Yamsailor
Yamsailor's Avatar
1) Tempest is correct;
2) "Special Circumstance" (referred in Rule 2) is most often defined as more than two vessels Meeting, Passing, or Crossing. In other words there is a Risk of Collision due to more than two vessels int the situation. That being said a Special Circumstance exitsts when "a situation is not specifically covered by the Rules or when there is a situation that justifies departure of the Rules." Note that In-Extremis is not a Special Circumstance. In-Extremis is a result of not taking action to avoid collision.
There isn't a device on this world that can measure the indifference I have for that statement.
Yamsailor is offline
post #23 of 463 Old 12-22-2009
Yamsailor
Yamsailor's Avatar
Ok--one more for today,
A vessel seaward of the Colreg line is Constrained By her Draft. What signals must she display:
1) Sunrise to Sunset?
2) from Sunset to Sunrise and at all other times where conditions warrant?
post #24 of 463 Old 12-22-2009
Depending upon it's length, all the lights required by Rule 23...
Plus
1.) A day shape....Cylinder..
2.)Three all around red lights in a vertical line
...where they can be seen best
tempest is offline
post #25 of 463 Old 12-22-2009
whughes's Avatar
Good One...
Originally Posted by midlifesailor View Post
"Futility is resistant, your ass will be laminated!"
whughes is offline
post #26 of 463 Old 12-22-2009
Two questions
...most often defined by who? Who are you citing?
can you provide an example of a special circumstance not covered by the rules?
tempest is offline
post #27 of 463 Old 12-22-2009
http://www.uscg.mil/legal/Suspension...0-%20PAYNE.pdf
Here's an interesting read. Where the claim of special circumstance was denied
tempest is offline
post #28 of 463 Old 12-22-2009
Yamsailor
Yamsailor's Avatar
Two questions
This is an interpretation laid down by case law from the courts. There are several citings, the easiest of which I think is in Farwells. I'll post it later tonight.
post #29 of 463 Old 12-22-2009
Yamsailor
Yamsailor's Avatar
Plus
Tempest is correct!
OK--now for the very last one of the day:
The same (large--greater than 65 feet) vessel is shoreward of the Colregs line, and is unable to maneuver due to the nature of her work and must stay within a channel. She shall display what:
1) From Sunrise to Sunset?
2) From Sunset to Sunrise and all other times that conditions Warrant?
post #30 of 463 Old 12-22-2009
Yamsailor
Yamsailor's Avatar
This is interesting...here is the citation from the decision:
Appellant next contends that no passing signal need have been
sounded by the MALASPINA because the special circumstances rule
permitted a departure from the ordinary rules of the road. The
special circumstances rule, however, has been construed as arising
only in those dire situations when adherence to the ordinary rules
would place the vessels in certain danger. The rule as set forth
in 33 U.S.C. 212, Article 7, Inland Rules, states as follows:
"In obeying and construing these rules due regard shall
be had to all dangers of navigation and collision, and to
any special circumstances which may render a departure
from the above rules necessary in order to avoid
immediate danger." (emphasis added)
It is Appellant's theory that the rule applies to this case because
as many as 16 small pleasure boats were present in Olga Strait when
the MALASPINA approached the southeast entrance. After the
MALASPINA sounded one long blast, however, her projected course was
cleared by all but two of the small vessels. As already set forth
in the findings of fact, there then followed a period of time
during which the MALASPINA was in an overtaking situation to the
FOREST. It was at this point that the proposal to pass ought to
have been sounded, and the special circumstances rule cannot be held to apply since, at this point, there was no evidence of
immediate danger to justify a departure from the established rules.
Furthermore, there was no evidence that Appellant did not have time
to give the required signal and wait for an assent. In The
MAGGIE J. SMITH, 123 U.S. 349 (1987) the Supreme Court held that
the special circumstances rule does not apply to vessels in
ordinary navigation which sight each other at an ample distance.
In Griffin on Collision, 228, p. 516, the author states that
the special circumstances rule "is not to be treated as a license
to disobey the ordinary rule when the navigator takes it in his
head to do so. There must be a sudden danger or an
unexpected development." (emphasis added) When the proposal
to pass should have been sounded, the FOREST was one of only two
small vessels in the channel. She was sighted from an ample
distance, and I can find no reason which would justify application
of the special circumstances exception.
Appellant cites The PAVONIA, 26 Fed. 106 (1885) for the
proposition that the special circumstances rule does apply to this
case. However, the court in The PAVONIA held only that if two
ferryboats which often pass each other, having adopted a method of
doing so understood and acted upon by both navigator, it may be
considered a special circumstance. There is no evidence that the
MALASPINA and the FOREST had adopted a passing agreement to this
effect. Therefore, the holding in The PAVONIA is not relevant
to Appellant's case.
I think this actually supports what I said earlier. The Special Circumstances claim was denied because the M/V Malaspina was subject to the overtaking rules and respective sound signals--for which it failed to comply. Special Circumstances are situations that requires the vessel to depart from the The Rules. In this case the court rules no circumstances existed that met the definition of Special Circumstance.
FYI--I am not a lawyer and admittedly there a lots of grey areas in this type of law.
Rules of the Road John Rousmaniere Learning to Sail Articles 0 12-28-2003 07:00 PM
Rules of the Road John Rousmaniere Seamanship Articles 0 12-28-2003 07:00 PM
Rules of the Road John Rousmaniere Her Sailnet Articles 0 12-28-2003 07:00 PM
Understanding the Racing Rules Dan Dickison Racing Articles 0 02-10-2002 07:00 PM
Understanding the Racing Rules Dan Dickison Her Sailnet Articles 0 02-10-2002 07:00 PM
