Celestial navigation (quiz) - Page 5 - SailNet Community
post #41 of 53 Old 02-14-2010
Originally Posted by AdamLein View Post
13 degrees... but I cheated and used a sextant
About 12 degrees, that's right.
Part of the significance of that measurement, by the way, is that 12 degrees is approximately the distance the moon moves through the zodiac from night to night.
What are you pretending not to know ?
Please support my
wind_magic is offline
post #42 of 53 Old 02-15-2010 Thread Starter
AdamLein's Avatar
Ooh, that's interesting... maybe I shouldn't have stretched so much. Could come in handy!
One thing that would be nice is to get 11.25 degrees, which is one point.
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #43 of 53 Old 02-22-2010
Boasun's Avatar
I don't see looking for the little known bits of celestial science will help.
But then you do need to understand working a celestial problem.
Such as What do they mean with "toward" or "Away" from the ground point?
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Boasun is offline
post #44 of 53 Old 02-22-2010 Thread Starter
AdamLein's Avatar
Not sure exactly what you mean here, but I think understanding what's going on "behind the scenes" helps give you (i.e., me) a better intuition for the whole operation, which is invaluable when solving problems (which is often done by rote).
Group point = GP = geographical position, right?
AdamLein is offline
post #45 of 53 Old 02-22-2010
Boasun's Avatar
Ground point is the assumed position you are using for that celestial body.
What is the meaning of toward or away and how do discern the difference?
This is part of your routine math problem that you have with each celestial body...
Maritime Instructor
S/V Rapture
Boasun is offline
post #46 of 53 Old 02-22-2010
The GP is not your DR or assumed position. It's the Ground Point of the celestial body under observation. That is, it's the point on earth which at the precise time of the sight lies directly under the celestial body you're using.
After you've determined the true sextant altitude of that celestial body (using your sextant and applying corrections), and you've determined the calculated altitude for that celestial body at the time of the sight, you compare the two and come up with a difference in minutes or nautical miles (nm).....say 8nm.
Now, you draw a line FROM your DR or assumed position TOWARDS or AWAY from the GP of the celestial body, using the calculated Azimuth. Then, you draw a perpendicular to that line and you have a line (part of a huge circle) on which the boat is somewhere located.
Here are the steps as listed on the BBC website:
"You would actually proceed as follows:
1. Measure the true altitude of the Sun.
2. Determine the tabulated altitude of your DR position.
3. Take the difference between them (in minutes, which is also nautical miles). Let's say it is eight miles.
4. Plot your dead reckoning position on the chart.
5. Draw a line towards (or away from) the Sun's geographical position using the azimuth from the DR position.
6. Measure off eight miles, or whatever your difference was.
7. At this point draw a line at right angles. This is a small part of the boat's position circle."
Bill
btrayfors is offline
post #47 of 53 Old 02-22-2010 Thread Starter
AdamLein's Avatar
I would add, for intuition purposes, that a body will get higher in the sky as you approach its GP (geographical position), and lower in the sky as you get farther away. So if computed altitude Hc is greater than the observed altitude Ho, that means that the assumed position is closer to the GP than you are.
AdamLein is offline
post #48 of 53 Old 02-23-2010
Omatako's Avatar
Yes and conversely if the Ho is greater than the Hc then it is further from the GP than you are. Hence towards and away. If it closer then your LOP is towards, if it is further then the LOP is away.
I'm interested in the concept of GP being a "ground point". I've always know it to be the geographcal position. I guess either one works, I've just never heard GP referred to as ground point before.
The best description of the GP is:
"If a line could be drawn between the celestial body and the centre of the earth, the point at which the line passes through the surface of the earth is the GP". That puts it into clear perspective (for me anyhow )
Arthur C. Clarke
Omatako is offline
post #49 of 53 Old 02-23-2010 Thread Starter
AdamLein's Avatar
Omo: I've never heard the term "ground point" before either but I can see it making sense as it's the point on the ground under the celestial body.
But okay let's move on to a new question:
The nautical almanac lists Greenwich hour angles (GHA) for the sun, moon, planets, and first point of Aries, and sidereal hour angles for the stars. For navigation, we need the local hour angle (LHA) for each.
1. Why the difference?
2. How do you compute LHA in each case?
AdamLein is offline
post #50 of 53 Old 02-28-2010
Guys, as mentioned earlier, I'm just starting to learn CN and also this also launched me into a general reading of basic astronomy. One question that came up today is this:
What is the difference between GHA and RA (right ascension)? It sounds like the same thing to me. Is it?
Also, is the celestial meridian (defined as the line extending from the North Celestial pole through the vernal equinox to the South Celestial Pole), the same thing as the Aries meridian?
M Murphy
magnusmurphy is offline
Basic Celestial Concepts Jim Sexton Seamanship Articles 0 06-28-2004 08:00 PM
Working With the Stars—Celestial Navigation Jim Sexton Seamanship Articles 0 05-06-2003 08:00 PM
Working With the Stars—Celestial Navigation Jim Sexton Her Sailnet Articles 0 05-06-2003 08:00 PM
Navigation Basics Jim Sexton Learning to Sail Articles 0 01-04-2002 07:00 PM
Navigation Basics Jim Sexton Her Sailnet Articles 0 01-04-2002 07:00 PM
