Navigation Questions. Can you do them? - Page 3 - SailNet Community
post #21 of 122 Old 02-28-2010
Last I checked, wouldn't that be 0˚T not 360˚T...
sailingdog is offline
post #22 of 122 Old 02-28-2010
Originally Posted by TheBishop View Post
If the wind is reported as 360T, it's coming from the North. If the current (set) is reported as 360T, it's going to the North. Who decided this, and was it done just to torture me?
I also have the same question and just suppose that it's just convention. Much like a circuit diagram in EE where electrical current is shown going from the positive to the negative post whereas in reality the electrons flow from negative to postive. Not sure how all this "conventional wisdom" got started.
lancelot9898 is offline
post #23 of 122 Old 02-28-2010 Thread Starter
Boasun's Avatar
The winds are named from where they are coming from because when you face into the wind you are looking in that direction. Thus the North wind is from the North because that is the direction you are facing.
About everything else is the direction they are going; Currents, Your Boat and so forth.
This is not that hard to understand... Not hard at all.
BTW: My post #13 here has not been answered yet... It is about figuring distance with a known chart scale.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Boasun is offline
post #24 of 122 Old 02-28-2010
AdamLein's Avatar
Originally Posted by Boasun View Post
One other:
the scale of a chart is 1:80,000. What distance at sea does a distance of 3.5 inches on the chart represent? What distance on the chart represents an actual distance of 14.3 NM?
3.5 in at 1:80,000 = 3.84 nm
13.3 nm at 1:80,000 = 13.03 in
Remember that a NM is 6076.11549 ft thought we use 6000 ft for practical purposes.
Okay,
3.5 in at 1:80,000 = 3.89 nm
14.3 nm at 1:80,000 = 12.87 in
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #25 of 122 Old 02-28-2010
jackdale's Avatar
You are closer than me.
Vol 5 of Canadian Tides and Currents uses 000 for currents flowing to True North.
I will have to fix that.
jackdale is offline
post #26 of 122 Old 02-28-2010
jackdale's Avatar
Boasun and others
Re: Chart scales.
I use Canadian Chart 3462 in my navigation class; it is 1:80,000 chart. However, the 1:80,000 is measured at 49˚ 30'N which is not on the chart. The top of the chart is 48˚ 54'N. As this is a Mercator projection, it seems to me that converting distances measured using the scale would not be exact.
In you view, would this be a correct interpretation?
jackdale is offline
post #27 of 122 Old 02-28-2010 Thread Starter
Boasun's Avatar
If the chart is 1:80,000 that means that you have 80,000 square inches representing land & water area squeezed into 1 square inch of the chart.
But when using the latitude scale on the chart for measuring distances, I have found that there can be a slight difference from near the bottom of the chart compared to the top of the chart.
Maritime Instructor
S/V Rapture
Boasun is offline
post #28 of 122 Old 02-28-2010 Thread Starter
Boasun's Avatar
How far will a vessel traveling at 16.5 knots travel in 34 minutes? In 2h 24m?
How long will it take a ship traveling at 14 knots to go 0.8 miles? To go 69 miles?
Maritime Instructor
S/V Rapture
Boasun is offline
post #29 of 122 Old 02-28-2010
Answers in bold
How far will a vessel traveling at 16.5 knots travel in 34 minutes? 9.35nm In 2h 24m? 39.6nm
How long will it take a ship traveling at 14 knots to go 0.8 miles? 2.98 minutes To go 69 miles? 4.29 hours.
post #30 of 122 Old 02-28-2010
tomaz_423's Avatar
Jacdale's post was spot on.
Boasun, you probably teach others this:
Chart is a flat paper representing a sphare. It is impossible to make it an accurate presentation.
Your statement is only true around one (reference) latitude. at any other latitude it is either less or more - but wrong.
Nautical charts are pretty accurate in representing angles, but not so good in representing surface areas. That is why we read distances at the closest left of right edge of the chart at about the same latitude as the distance was taken.
If we would only measure that distance and multiply it we could not get a very accurate result.
The error is neglectable for charts representing small areas, but can be significant in a general charts like Ca4700 or US13003.
Beneteau Oceanis 473
finished cruising after two years.
tomaz_423 is offline
Working With the Stars—Celestial Navigation Jim Sexton Seamanship Articles 0 05-06-2003 08:00 PM
Working With the Stars—Celestial Navigation Jim Sexton Her Sailnet Articles 0 05-06-2003 08:00 PM
Navigation Basics Jim Sexton Learning to Sail Articles 0 01-04-2002 07:00 PM
Navigation Basics Jim Sexton Seamanship Articles 0 01-04-2002 07:00 PM
Navigation Basics Jim Sexton Her Sailnet Articles 0 01-04-2002 07:00 PM
