Celestial Navigation: Nautical Almanac - Page 2 - SailNet Community
 1Likes
post #11 of 22 Old 04-20-2010 Thread Starter
I know. I have an Aristo. I had a life raft use case in mind. Really no electronics involved.
Here a picture of it:
http://sliderule.ozmanor.com/rules/i...ront-right.jpg
SeppSF is offline
post #12 of 22 Old 04-20-2010
AdamLein's Avatar
Very nice. I use a Pickett ES-800:
http://sliderule.ozmanor.com/rules/i...front-left.jpg
Except mine has red numbers on the reverse scales and slightly different end pieces and indicator.
Do you know of any tricks to solve the navigational triangle with a slide rule? In particular in cases where the trig scales lose precision, like for sines near 90.
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #13 of 22 Old 04-20-2010
Mirage 29
sailjunkie's Avatar
If this is a bit off-topic then I apologize in advance.
If one is going off-shore, then I can definitely see why mastering celestial navigation is a VERY good idea.
However, for coastal cruising in the PNW, piloting skills are a must. CPS and Cdn. Yachting Assn both offer excellent courses.
While I remain fascinated by celestial navigation, it is usually too cloudy here in the rain forest.
Mark
S/V Avatar
Mirage 29'
Port Moody, BC
It's not my fault they named a movie after our boat
sailjunkie is offline
post #14 of 22 Old 04-21-2010
AdamLein's Avatar
Totally agree. I don't expect to ever resort to CN in our local waters. If I really didn't know where I was, landmarks, bottom contours, and other sources of information from coastal piloting are much more useful and timely.
However, I would like to cruise some day in places where CN skills make sense, so I might as well practice now.
I've been surprised at how often I could get good sights. The right combination of filters often punches through clouds that obscure or blur the sun to the naked eye. Overcast, rainy skies are basically hopeless, but if the sky has patches of bright cloud and dark cloud, the bright spots are often transparent under filters and a crisp solar disc can be seen through them.
AdamLein is offline
post #15 of 22 Old 04-21-2010
Mirage 29
sailjunkie's Avatar
Adam, places where CN makes sense means warmer climes than PNW. That makes 2 of us!
Mark
S/V Avatar
Mirage 29'
Port Moody, BC
post #16 of 22 Old 04-21-2010
AdamLein's Avatar
Everything makes more sense in the tropics
AdamLein is offline
post #17 of 22 Old 04-02-2012
AdamLein's Avatar
Re: Celestial Navigation: Nautical Almanac
Originally Posted by milutin View Post
hello there....
Hc -0.57' and Ho is 43deg 38'.2
Sounds like something went wrong when you did the computations. Can you give all the details?
One possibility is that you used an assumed position very far from your actual position. Another is that you used Pub 249 incorrectly, which is very understandable as I mess it up all the time. Make sure you use the correct table, including same name vs. contrary name.
So, what's your AP, what star, and what time of observation?
AdamLein is offline
post #18 of 22 Old 04-02-2012
For sun sights , almanacs repeat themselves every 4 years. So get 4 years in a row and you have all the backup you need for sun sights. Even one several years out of date is only about three miles out on sun sights.
I can tell people how to take a noon sight in about 5 minutes.
jerryrlitton likes this.
Brent Swain is offline
post #19 of 22 Old 04-02-2012
AdamLein's Avatar
Brent, if he's got a computed altitude, he probably isn't doing a noon sight.
AdamLein is offline
post #20 of 22 Old 04-02-2012
AdamLein's Avatar
Nice. That's what practice is for.
By the way, if Procyon's computed LHA is 358°58.4' then I think it makes more sense to round up to 359° for the purpose of indexing Pub 249, no? That means you should use the row above.
Also, you need to interpolate between 5° and 6° of declination. If your computed declination has 11.4' attached, and d = 60', then you need to add 11.4' to Hc, which brings you up to Hc = 43°11.4'. This is a lot closer to your Ho of 42°38.2'.
AdamLein is offline
Basic Celestial Concepts Jim Sexton Seamanship Articles 0 06-28-2004 09:00 PM
Working With the Stars—Celestial Navigation Jim Sexton Seamanship Articles 0 05-06-2003 09:00 PM
Working With the Stars—Celestial Navigation Jim Sexton Her Sailnet Articles 0 05-06-2003 09:00 PM
Navigation Basics Jim Sexton Learning to Sail Articles 0 01-04-2002 08:00 PM
Navigation Basics Jim Sexton Her Sailnet Articles 0 01-04-2002 08:00 PM
