Reefing and Heaving to. - Page 2 - SailNet Community
 2Likes
post #11 of 18 Old 07-08-2010
I'd point out that the Storm Tactics book really isn't designed for modern sailboats...it wasn't really written with high-aspect bulb keel boats in mind. It also wasn't written with multihulls in mind. While the book, updated last in 2008 for the 3rd edition, is a great resource...saying it is for modern sailboats is not quite right.
I'd point out that much of the information in the book does apply, to a degree, to modern sailboats, a lot of it isn't all that useful. For instance, the "slick" that is created when heaving-to doesn't really happen with a high aspect bulb keeled boat. This makes heaving-to a slightly less useful storm tactic for a modern high-aspect keel boat in storm conditions. This isnt' to say that heaving-to doesn't work on a modern design, but it does lose a lot of its value as a storm survival tactic IMHO.
Originally Posted by casioqv View Post
I highly recommend this book on heaving to in modern sailboats:
Storm Tactics Handbook: Modern Methods of Heaving-To for Survival in Extreme Conditions
by Lin Pardey, Larry Pardey
I've found that with a 110 jib on my C22, the backwinded jib overpowers the main, and pushes the bow too far off the wind for proper 45-50 degree angle from the wind. My C22 will heave to better under the main alone, but I don't have a small 90% jib as you do.
It seems like fore-reaching becomes a problem when winds are too strong. If the C22 is fore-reaching, perhaps get a deeper reef installed in your mainsail, and a smaller jib (or no jib).
A parachute sea anchor rigged with a pendant line will also prevent the boat from fore-reaching, and make it possible to heave-to under bare poles for severe weather:
sailingdog is offline
post #12 of 18 Old 07-08-2010
casioqv's Avatar
??? It specifically addresses the issues of heaving to multihulls and high-aspect bulb keel boats, including specific case studies, testimonials, and techniques for these boats.
While the Pardeys themselves have a more traditional boat, they do yacht deliveries and test these techniques on modern boats.
I can't say from personal experience that a modern boat wouldn't create a slick, but it seems to me that any boat (even a powerboat) would be able to create and remain under a slick if lying at a hove-to angle under a parachute sea anchor.
Also- we're talking here about the C22, not an Open 40.
casioqv is offline
post #13 of 18 Old 07-08-2010
Hmm... I'll have to see which version I have... I thought I had the 2008 3rd edition...that may not be the case then.
post #14 of 18 Old 07-08-2010
casioqv's Avatar
Same version I have.
casioqv is offline
post #15 of 18 Old 07-08-2010
F4d3d's Avatar
Originally Posted by jackdale View Post
BTW - I recommend heaving-to from a port tack;this puts you on a starboard tack, making you stand-on to more vessels.
Awesome tip! Thanks!
F4d3d is offline
post #16 of 18 Old 07-09-2010
Mirage 29
sailjunkie's Avatar
Very good points here. One additional step is to put the rudder over to windward. The boat will want to point into the wind, and the back-winded foresail will counter that. As noted above, there will be some "crabbing" movement, but the boat will be quite stable.
Mark
S/V Avatar
Mirage 29'
Port Moody, BC
It's not my fault they named a movie after our boat
sailjunkie is offline
post #17 of 18 Old 11-09-2015
Re: Reefing and Heaving to.
Originally Posted by alanr77 View Post
Anyways, enough about magic. To anyone learning to sail- This stuff really works and it would behoove you to learn it now. Don't wait until you need it but can't do it like me. I am a glutton for punishment. Practice reefing and heaving to when the conditions are manageable. You will thank yourself for it. Its better than the first time you saw color TV.
Sorry to dig up this old thread, but stumbling upon this thread is what convinced me that I needed to get serious about getting familiar with these two things. I got to get out sailing yesterday and had the chance to practice both reefing and heaving to. I came to a similar conclusion. It was awesome!
Thanks alanr77!
Tom
Be humble for you are made of earth.
Be noble for you are made of stars.
T.Bird is offline
post #18 of 18 Old 11-16-2015
Master Mariner
capta's Avatar
We, as do most who sail the Windward and Leeward Islands, rarely begin a day's sailing without a reef or two in the main. It's a whole lot easier to shake out a reef in lighter air than expected than tucking one in, in heavier weather than expected.
oysterman23 likes this.
facebook.com/svskippingstone
Our Videos;
capta is offline
Mainsail reefing dilemma aflanigan Gear & Maintenance 18 04-18-2003 03:58 PM
