Terminology question: Gybing - SailNet Community
post #1 of 30 Old 07-05-2010 Thread Starter
zAr
So this past weekend with the boat on a broad reach starboard tack I wanted to put the boat on a broad reach port tack.
I (as skipper and helm) explained to my crew what I intended to do, saying I wanted to put us on a broad reach port tack, so let's gybe.
One crew member went...ballistic, saying I'm not using the term correctly, that gybing does not involve a course change, only bringing the boom over to the other side without changing course.
I said yes, that's an essential step for gybing (nudging the boom over while maintaining downwind run), but gybing can also mean changing course, that if we're on a broad reach what reason could we possibly have for putting the boom over without changing course (and sailing by the lee)? Therefore, logically, when on a broad reach the instruction is given to gybe, it can only mean we will steer to at least a run and to the other tack, thus changing course.
Your thoughts? This led to quite a distracting argument.
RS
zAr is offline
post #2 of 30 Old 07-05-2010
From Dictionary.com
Ėverb (used without object)
1.
to shift from one side to the other when running before the wind, as a fore-and-aft sail or its boom.
2.
to alter course so that a fore-and-aft sail shifts in this manner.
2xtiger886
Looking for a 22-25 footer
To Be Sailed on Mark Twain Lake in Missouri
2xtiger886 is offline
post #3 of 30 Old 07-05-2010
Crealock 37
sailak's Avatar
Dock
I've always thought of a gybe as a course change in which the stern moves through the eye of the wind.
Dale
S/V Elnora
Pacific Seacraft "Crealock" 37 #312
sailak is offline
post #4 of 30 Old 07-05-2010
Same here, I always understood that if you change course from a broad reach with wind on one quarter and the stern went through the eye of the wind to a broad reach with the wind on the other quarter, you just gybed, no matter which side the boom is on. Of course, hopefully you gybed the boom too so that it doesn't accidentally gybe later!
What are you pretending not to know ?
Please support my
wind_magic is offline
post #5 of 30 Old 07-05-2010
Your crew member was wrong. Gybing is simply moving the leach of the mainsail, rather than the luff, through the wind. You can be on a broad reach, in which case gybing will involve a course change, or you can be on a dead run, in which case it will not.
Jim
SEMIJim is offline
post #6 of 30 Old 07-05-2010
1975 Newport 28
jaschrumpf's Avatar
If you move the boom across the boat without changing course, you've now backwinded the main. Very dangerous, and prime for a crash gybe the other way. [Edit - unless, as SEMIJim said, you're on a dead run]
My thoughts on a crew member arguing a semantic point with me while I want to maneuver? "Do what I want, NOW, and we'll discuss how you're wrong later."
Because, you see, even using his definition he was wrong. You said you wanted to change course to a broad reach port tack from your broad reach starboard tack, so let's gybe. You said you wanted to change course; you said you wanted to gybe. His argument seems to be that merely saying "let's gybe" does not imply a course change -- but you said you wanted (1) a course change (2) therefore, let's gybe.
He's wrong and wrong.
S/V Free Spirit
Monrovia, MD
jaschrumpf is offline
post #7 of 30 Old 07-05-2010
Yup. I'd offer a "look it up when we get back, but for now, we're 'gybing'. You explained what you wanted to so, so even if you said, "farfignugen", the instructions where there for the following. Arguing on a boat, if the instructions and desired results are clearly explained, just isn't good for anyone. Matter of fact, arguing on the boat just isn't done with folks who respect each others skills.
puddinlegs is offline
post #8 of 30 Old 07-05-2010
FSMike's Avatar
My thoughts on a crew member arguing a semantic point with me while I want to maneuver? "Do what I want, NOW, and we'll discuss how you're wrong later." --
ROFL Well said.
Sail Fast Live Slow
36' Solaris Sunstar catamaran
FSMike is offline
post #9 of 30 Old 07-05-2010
Boasun's Avatar
Encyclopedia of Nautical Knowledge; Cornell Maritime Press:
GYBE. (Du. gijben, to shift) To shift position of a fore-and-aft sail from one side to another; as, when sailing before the wind, or when altering course so that wind is brought on the opposite quarter. Also gibe; jibe.
Any questions?
Seems as if zAr is correct in his deffination.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Boasun is offline
post #10 of 30 Old 07-05-2010
The term gybe and execution of 'only a gybe' might not involve a course change. I can tell you it doesn't, like tacking, imply any minimum course change. When going from a beam reach to beam reach on opposite tacks you could either head up and perform a tack or bear off and perform a gybe.
While your manuever did not include only a gybe ... it certainly did include a gybe.
1981 C&C 32
scraph is offline
Another House v Boat Question creedence623 Cruising & Liveaboard Forum 5 05-11-2010 04:25 PM
Stupid Question krozet Boat Review and Purchase Forum 15 10-11-2009 11:30 AM
Ladder question mcain Gear & Maintenance 14 08-03-2007 10:28 PM
terminology question locrian13 General Discussion (sailing related) 6 02-23-2004 02:07 PM
terminology question petith General Discussion (sailing related) 4 10-30-2002 02:42 PM
