Sailing downwind is much harder than sailing upwind. - Page 4 - SailNet Community
 8Likes
post #31 of 48 Old 06-26-2014
jackdale's Avatar
Re: Sailing downwind is much harder than sailing upwind.
Originally Posted by Minnesail View Post
Wait, what?
Isn't apparent wind always ahead of true wind? If the true is on the beam wouldn't the apparent be ahead of the beam, like a close reach?
I have trouble visualizing this sometimes.
That is true. You are correct.
http://www.sailingcourse.com/keelboa...calculator.htm
jackdale is offline
post #32 of 48 Old 06-26-2014
I've given it some more thought and you are right. The only explanation I can think of is that the wind direction is genuinely shifting, then.
MarkSF is offline
post #33 of 48 Old 06-26-2014
Windseeker
Check VMG while gybing and while wing on winging. Quite possibly better wing on wing despite the lower speed. Without a spinnaker I tend to just gybe on deep angles (140 in lighter air, then deeper) because I prefer sailing that way and it allows me to try and take advantage of shifts but I've read that direct downwind wing on wing with the jib poled out is more effective.
Really though you need a different head sail. Jibs / Genoa's are just not designed to sail deep like that. If you're worried about jumping to a poled out symmetrical (which is a fair leap without prior experience) see if you can find an asym and a sock. They really open up performance both downwind and while reaching plus it gives you something to do at exactly the point you might otherwise get both hot and bored.
If I'm serious about going somewhere downwind I fly a spinnaker.
theonecalledtom is offline
post #34 of 48 Old 06-26-2014
Once known as Hartley18
Classic30's Avatar
Dock
Wait, what?
True and Apparent Wind Calculator
No, Jack - that is only true if you are moving. Otherwise apparent wind is the same as the true wind.
Just sayin'...
Minnesail likes this.
Classic30 is offline
post #35 of 48 Old 06-26-2014
4KSB driver.
SHNOOL's Avatar
This is a fantastic topic for newbies, but it's also a great topic for long time sailors... Because we sometimes get bogged down in details, and forget to approach it simply...
One thing that has been bugging me lately (keep in mind I've sailed a lot of slower sailboats, in light air)... Broad reach rarely brings the AWA as per the masthead much past 90 degrees, until I am nearly pushing DDW, or say 150-160 TWA.
In the same winds beam reach, I'll see something like 50-55 AWA, and say I am doing roughly 6 knots... with perhaps 8-10 knots true. I'm flying a 155, and full main, as I fall off though, and ease, I can feel the boat slow considerably... 4.5 to 5 knots... Closer to 4 knots wing on wing. My point is broad reach barely shows 90 on the windex, until I am pushing say 150 true wind angle. Sounds like you all are confirming what I am seeing. Not sure why I never noted any of this before, I have a tendency to trim by feel though so perhaps my focus is usually on other things.
Actually just the other day I was running DDW wing on wing (actually about 170 degrees as even wing on wing you have to be off 180 a bit to keep the genoa filled)... heeled to windward a bit (to try to neutralize helm), with whitecaps and rollers in say 14-16 knots wind... I was surfing, and digging, and popping back out... a wild experience at 8-9 knots boat speed! Chasing down an S2 7.9 (which by the way does much better downwind, at least until I whip out the masthead kite, which would have been a chore solo in that stuff). Anyway, a good steady breeze, and you can tweak to your hearts content to find out what works best...
PS: The S2 7.9 is a fractional, with a large roachy main (making it seemingly easier to trim downwind), my Capri is a balanced rig, with most of its sail area forward, so presenting the proper area downwind is touchy (leaving deep angles out of my reach)... again until that masthead kite comes out, then its GAME ON!
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
post #36 of 48 Old 06-28-2014
jackdale's Avatar
Just sayin'...
jackdale is offline
post #37 of 48 Old 06-29-2014
Classic30's Avatar
Dock
As you might have guessed... I'm an 'expert' at this: I spend much of my time going nowhere.
post #38 of 48 Old 06-30-2014
blt2ski's Avatar
You know, if you if you would get rid of that OOOOOOOOLD woody boat you have, you might figure out what apparent wind really is!LOLOLOL
Then again, if you did that, those old woodies moght go bye bye.....that would be bad too! hmmmmmmmm
decisions and disCUSSions to follow!
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #39 of 48 Old 06-30-2014
Classic30's Avatar
Dock
Marty
ROTFLOL!! Marty, as usual you are so RIGHT!
If ever you are over this way, you and me need to go for a sail (or more likely a "sit" if the wind isn't blowing at least 10kts...)
post #40 of 48 Old 06-30-2014
blt2ski's Avatar
If you can get your boat up here in the next day or two, there are some 20-30 knot winds predicted in the straight of juan de fuca, even 10-25 here in the main part of the southern salish sea.....should make your boat move some I'd reckon. With something called a gps coordinate, not really sure what what of them is, or at least a real paper chart, I should be able to find the home of the WILD or is that WILEY BP and maybe we can talk him into going out and entertaining us with that stringed thingy he plays.......no need to ruin my hearing any more with his singing........did I really type that?
Marty
Classic30 likes this.
She drives me boat,
I drives me dinghy!
blt2ski is offline
