Motor Sailing Question - SailNet Community
post #1 of 12 Old 11-28-2010 Thread Starter
We were sailing on a chartered Beneteau 37 last week in ~12knts of wind beating to windward at about 5 knots. We were running late, so I started the diesel to push us up to hull speed (7kts). My buddy told me this is bad for the engine. As long as the intake doesn't cavitate, is there anything wrong with this practice?
Thanks,
Dave
Hewie is offline
post #2 of 12 Old 11-28-2010
It depends on the engine.. some engines have limited permitted heel angles - though any marine engine worth its salt should have considerable tolerance there.
We strive to keep the heel off the boat while running the engine.. just because. But we know many others who 'motorsail' as much as anything, in virtually all conditions.
Faster is online now
post #3 of 12 Old 11-28-2010
I don't think so. Why does your friend think it is bad for the engine?
post #4 of 12 Old 11-28-2010 Thread Starter
Some babble about the variations of forces from the water on the prop can damage the transmission.
Dave
Hewie is offline
post #5 of 12 Old 11-28-2010
That makes no sense.
post #6 of 12 Old 11-28-2010
CaptainForce's Avatar
I have over 5,000 hours on my basic maintenance and trouble free Yanmar with motor sailing being a very common practice. I also motor in currents which would simulate the same effect without the heel. 'sounds like this guy is among those that would also think that drafts cause colds or reading in dim light can damage your eyes! Take care and joy, Aythya crew
CaptainForce is offline
post #7 of 12 Old 11-28-2010
I was worried about that and I have asked to a Volvo-Penta authorized mechanic. He said that the engine is prepared to work with any reasonable heel angle. My engine had more than 2200 hours and was just fine. Many times I had done what Hewie has done, sometimes close to the wind and that means at least 15/20ş heel.
post #8 of 12 Old 11-28-2010
tomaz_423's Avatar
Just make sure that:
- water intake is sucking in water, not air
- oil pump is sucking in oil and not air.
If you have normal instrument for the engine you would get alarm the moment your oil pump will suck air (low oil pressure alarm).
If you are not getting enough cooling water you would get high temperature alarm before you would ruin your impeller or engine.
If this happens reduce heel.
Beneteau Oceanis 473
finished cruising after two years.
tomaz_423 is offline
post #9 of 12 Old 11-28-2010
A friend had a Laser 28 with a Bukh engine... running it heeled hard on one tack (but not the other) dumped all the oil into the bilge.
post #10 of 12 Old 11-29-2010
Unless you were heeled way over...I don't see a problem with motorsailing at hull speed, other than possibly running the engine at WOT RPM for too long or wasting a lot of fuel... since hull speed is quite inefficient in terms of fuel consumption.
sailingdog is offline
yamaha outboard question with video. t9.9elhp motor Incantation Gear & Maintenance 5 10-27-2010 01:06 PM
Motor question glc482 General Discussion (sailing related) 27 03-25-2010 08:34 PM
Motor: DIY or Pay up; that is the question canoeman256 General Discussion (sailing related) 11 10-11-2008 05:16 PM
outboard motor newbie question calamitas Gear & Maintenance 5 06-08-2007 08:31 AM
No clue re: outboard motor!? Saltwater question! Cony Gear & Maintenance 7 03-13-2004 06:22 PM
